Can you connect a Wireless Access Point to Another Wireless Access Point
avg123
Currently I have a wireless AP connected to my router. Can I connect another Wireless AP to my existing AP? Or do I need to connect it with my main router?
There is a thing called a "Reverse AP" that will connect to a wireless network and then let you plug additional devices into it like a switch if that's what you mean
I mean like daisy chaining APs like Main router----ethernet cable---->AP------ethernet cable---->AP
It can also be called a wireless bridge.
Asus Z77 Sabertooth, Intel Core i5 3570k 4.2 GHz, EVGA GTX 780, Corsair Vengeance 16Gb ,
Samsung EVO 250&500Gb, Western Digital Black 2TB,  Corsair RM 750
Custom Water Loop
CPU Block Koolance 380iGPU Block EKWB Clean CSQPump Laing DDC w/ EKWB X-RES 100Radiatiors NexXxoS Monsta 240 & Swiftech 240x35Tubing PrimoChill Primoflex Advanced LRT Elegant White 3/8" ID 5/8" ODFittings White Monsoon Free Centre Compression Fittings 3/8" ID 5/8" ODFans6x Noctua NF-F12 w/Noctua LNA Adaptors
yes u can chain as many ap,s as u want with cable to cable :P aslong its only used for wifi
I suspect that an AP with multiple ethernet ports internally has a switch or at least a hub, which if you're only plugging in two things should be fine, in which case doing this would work and should be easy
more like Router----siwtch--|----------siwtch--|----------siwtch--|
                                          AP                     AP                    AP
That only applies to pure APs. But it you are trying to use existing wifi routers you could just daisy chain. Just remember that everytime you do that you are NATing a NAT which could cause a fuck ton of issues on the far end APs
yes if you using a router as an AP it basically becomes a switch also
