8 minutes ago, Cyberspirit said:
Well then if you want really tinted ones then you could get one with tempered glass but those are really expensive.
Ideally you could just get a nice case and mod it but that can be very troublesome.
i though about that but all the cases i have wanted to mod are in the us
https://linustechtips.com/topic/843098-need-help/page/2/#findComment-10522048
Also here's a thread about tinting that might be useful:
http://www.overclock.net/t/1252184/side-panel-window-tinting
i thought about getting this and tinting it
https://www.pccasegear.com/products/35198/deepcool-dukase-v2-mid-tower-case-with-window-black
https://linustechtips.com/topic/843098-need-help/page/2/#findComment-10522074
3 minutes ago, rasfsfsd said:
Before doing so make sure to research tinting just so you don't mess it up.
Make sure to quote or tag people, so they get notified.
https://linustechtips.com/topic/843098-need-help/page/2/#findComment-10522084
2 minutes ago, rasfsfsd said:
one last thing which is better air or liquid cooling
Well air is better because it's cheaper and the big coolers usually cool just as well as an AIO.
Also air is usually quieter since you don't have to deal with pump noise and failure.
Some people don't like big air coolers but personally i love them.
https://linustechtips.com/topic/843098-need-help/page/2/#findComment-10522111
yeah too be honest all i care about is the tinted window and putting rgb fans on the cooler, how would i go able picking the right air cooler for my build
https://linustechtips.com/topic/843098-need-help/page/2/#findComment-10522119
To be honest all i care about is the tinted window and putting rgb fans on the cooler.
Well i don't think it's a good idea to replace an air coolers's stock fans with probably worse RGB ones.
The cooler might perform worse honestly.
4 minutes ago, rasfsfsd said:
How would i go able picking the right air cooler for my build
Well you could ask people here in the Air cooling section for what they recommend.
Noctua and Be Quiet are both great but Be Quiet's coolers look better but they are a pain in the ass to install sometimes.
https://linustechtips.com/topic/843098-need-help/page/2/#findComment-10522136
