2 minutes ago, rasfsfsd said:
i need help seeing if i have picked the right parts or if there is a way to lower the price with the performance
https://au.pcpartpicker.com/list/vzQDPs (i'm in Australia and i would prefer if the part weren't coming from all different places)
thank
You should get faster RAM because Ryzen performs better or worse depending on the RAM speeds.
Make sure to quote or tag people, so they get notified.
https://linustechtips.com/topic/843098-need-help/#findComment-10521785
3 minutes ago, rasfsfsd said:
ok, what speed should i get and would it be better to just do a intel build
Ryzen is a good choice but if you can wait a month or so by then the Coffee lake CPUs and their benchmarks should be out.
Ths is what i'd get.
https://linustechtips.com/topic/843098-need-help/#findComment-10521792
Well that's still not the best but for liquid cooling it's probably good.
https://linustechtips.com/topic/843098-need-help/#findComment-10521809
9 minutes ago, ImNotThere said:
i used to want an expensive case but if you got a cheaper (like 100 dollar) case you could afford a 1070 which would help you so much, or 16 gb of ram which is quickly becoming needed
alright do you have any ideas case with a darken window
https://linustechtips.com/topic/843098-need-help/#findComment-10521997
wait do you think it would be possible to get it tinted myself
i mean if you want to, the p300 looks slightly tinted, tinting isnt cheap and i woukdnt bother with high end beautiful cases when i can get more raw performance with decent mid range cases that look phenominal
https://linustechtips.com/topic/843098-need-help/#findComment-10522028
4 minutes ago, rasfsfsd said:
i just like the look of the tinted window when the inside is lit up
Well then if you want really tinted ones then you could get one with tempered glass but those are really expensive.
Ideally you could just get a nice case and mod it but that can be very troublesome.
Also here's a thread about tinting that might be useful:
http://www.overclock.net/t/1252184/side-panel-window-tinting
https://linustechtips.com/topic/843098-need-help/#findComment-10522041
