Are you not satisfied with the stock cooler? What are you looking for in a cooler?
https://linustechtips.com/topic/842947-what-cooler/#findComment-10521981
17 hours ago, Thomas S said:
Nothing specific I just assume it will be better in the long with with a cooler.
If your temps are fine and there's no problem you're having with the stock cooler, there's no need to replace it.
https://linustechtips.com/topic/842947-what-cooler/#findComment-10525939
