Help with my FPS.
Go to solution Solved by Bluejay0,
Check your NVIDIA control panel, there is an option for VSYNC. Turn it off and see how that goes.
I am confused too. Maybe a virus?
| Case: NZXT Tempest 210 | CPU: Intel Core i5 3570K @ 3.9 Ghz | GPU: ASUS ROG STRIX GTX 1070 | RAM: Crucial Ballistix Tactical 8GB |
| Mouse: Zowie FK1 | Monitor: Acer 21.5' | Keyboard: CoolerMaster Stealth w/ Brown Switches |
#KilledMyWife - #LinusButtPlug - #1080penis
https://linustechtips.com/topic/84261-help-with-my-fps/#findComment-1147140
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/84261-help-with-my-fps/#findComment-1147141
you got a screen that can output more than 60hz?
Doesn't matter if the monitor only outputs 60Hz, games can output more.
https://linustechtips.com/topic/84261-help-with-my-fps/#findComment-1147147
I know... Whats your point? If he has a 60hz moniter it wont matter if its stuck at 60 frames
He means in game frame count, not total output visual frame count
https://linustechtips.com/topic/84261-help-with-my-fps/#findComment-1147161
I know but if he DOES have a 60hz moniter it wouldent matter if its stuck at 60....
The advantage of higher frames, if you didn't know, was if that any performance impact like explosions or long range vision will be still having a smooth visual gameplay due to the extra frames able to be sacrificed while will maintaining a smooth 60 frames.
https://linustechtips.com/topic/84261-help-with-my-fps/#findComment-1147277
Jeez, you have no idea what you're talking about. I suggest you do some reading.
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the former."
- Albert Einstein
https://linustechtips.com/topic/84261-help-with-my-fps/#findComment-1148318
No your the one that needs to do your reading kid
You clearly have no idea of the problems VSync introduces, so yes, you should restrain from posting ignorant posts like that.
- Albert Einstein
https://linustechtips.com/topic/84261-help-with-my-fps/#findComment-1150985
