HD558, sound card?
Thanks guys, I guess I'll just save the cash. Can anybody describe the improvements I'd get from an amp like the fiio e10? Louder volume? Better sound quality? If it's just a minor difference then I'd also rather save the $75 (fiio e10 price), as my budget is really running out after I bought a new rig.
Also one other question, is it possible to get virtual surround with the headset or should I forget about this? (There is an option in the Realtek app)
This is going to be my first real 'good' headset so rest assured I'm an amateur at this
The FiiO can probably make them louder, and will have a minor improvement in sound quality, but it's probably not worth it. Internal soundcards are crap so everyone was just giving you an alternative.
You can try the realtek virtual surround option, and you can also try the Razer Surround software if you don't like the Realtek stuff. Most people think virtual surround sounds bad on good headphones, so you might not like either.
Stop calling headphones headsets. The distinction is big. ![]()
