Hello !
I need help. Im making a simple page for people to post messages that are updated 3-4 times per week. for people with absolutly 0 knowledge of computers.
im currently doing a form that stores the info in a variable (as a string with html code in it)
I want to, when I click "update"  that the server takes that string, copy it and replace the text inside the index.html file somewhere else on the website (the display page)
how do I do that ?
https://linustechtips.com/topic/841877-htmljs-help-turn-var-into-indexhtml/
are you using php?
use the form to submit to a php page that will take the form data and store it in a database.
On your index page, make a php script that pulls from the data base to display the form data.
here is a tutorial https://www.w3schools.com/php/php_mysql_intro.asp
ψ ︿_____︿_ψ_
Just now, SCHISCHKA said:
are you using php?
iv never done php, and my db skills are very low. I barely know how to make it work, never actually pulled data from a server.
I ill try. but if there's a simpler solution that would be great.
Thanks.
using a database is the simplest solution, otherwise you would be trying to replicate all the things that a database does.
ψ ︿_____︿_ψ_
2 hours ago, givingtnt said:
Hello !
how do I do that ?
I can think of a way of doing that using a Node.JS server and AngularJS, but it's more of a weekend project sort of deal if you haven't done full-stack before.
im pretty far from being a full-stack dev xD
im in college still :S
If it's a demo site though, something you don't necessarily need a server for, you can do HTML and AngularJS or JQuery. JQuery's easier to wrap your head around, but AngularJS does a lot of automagic things.
But if you want some help I can do so over PM whenever I can get to it.
that would be cool
basically, all I want to do is be able to put text in different sections. and have it update the view page.
Just now, givingtnt said:
that would be cool
https://www.w3schools.com/angular/angular_model.asp
Let me know how easy or hard that is to understand :3
I think I can understand the structure, but iv never done angular or JQ xD just plain JS
