Help with PC Build!
Go to solution Solved by Sage_Masters,
1 minute ago, SergeantBlake23 said:
Do you have a Build where i don`t have to upgrade my pc for the next 5-7 years but still play AAA games of those years?
Okay il list some hardware and you can check different prices at your local store
CPU: ryzen 7 has a good life time span only because the 7th intel core i5 and i7 would be put away from intel 8th gen so waiting to get a 8th gen core i7 can last you
GPU: 1070 or 1080 are good with a long life span currently with the new architecture
RAM : unless you doing more than just gaming on your system I dont see how AAA Games can use more than 16gigs
Get a Mobo and PSU with 5 year warranties
The standard for 2017 run ssd and hdd
Just now, SergeantBlake23 said:
Thanks alot dude epic build definitely look into it!
no keyboard
no mouse
no display
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
