can you recommened an LED power supply for this:
Solved by Unimportant,
21 minutes ago, NoTxtWhileDrive said:Also worth noting that there are two positive and two negative wires in each light, I just connected the one negative and positive end together, and the other pair to the positive and negative of the batteries, Is that how I'm supposed to do it?
No, That would be a short circuit. Both sides are simply connected trough (+ to + and - to -). It's meant to allow chaining multiple strips together in parallel. Just connect the + of one side to the + of the batteries and the - of one side to the - of the batteries, leave the other 2 connections unconnected.
