Hi I have just put together my first ever build, see the pcpp link for details.
https://uk.pcpartpicker.com/user/matio57/saved/stK3FT
I have followed PC build guides and put everything together myself.
Upon turning it on, I don't get any signal to my monitor. The fans start running and the mobo led's light up but upon plugging in my mouse and keyboard via the USB sockets directly on the mobo neither receive power or turn on. What do I need to check?
https://linustechtips.com/topic/840961-first-build-not-working/
Try connecting the monitor to your motherboard for starters
https://linustechtips.com/topic/840961-first-build-not-working/#findComment-10497469
Thats a Ryzen chip no igpu with that one discrete graphics only
My daily driver: The Wrath of Red: OS Windows 10 home edition / CPU Ryzen TR4 1950x 3.85GHz / Cooler Master MasterAir MA621P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / ASRock x399 Taichi / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / Samsung 512GB 970 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor x3
My technology Rig: The wizard: OS Windows 10 home edition / CPU Ryzen R7 1800x 3.95MHz / Corsair H110i / PSU Thermaltake Toughpower 750watt / ASUS CH 6 / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / 512GB 960 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor HP Monitor
My I don't use RigOS Windows 10 home edition / CPU Ryzen 1600x 3.85GHz / Cooler Master MasterAir MA620P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / MSI x370 Gaming Pro Carbon / Gskill Flare X 32GB DDR4 3200Mhz / Samsung PM961 256GB M.2 PCIe Internal SSDEVGA GeForce GTX 1050 Ti SSC GAMING / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor
My NAS: The storage miser: OS unRAID v. 6.9.0-beta25 / CPU Intel i7 6700 / Cooler Master MasterWatt Lite 500 Watt 80 Plus / ASUS Maximus viii Hero / 32GB Gskill RipJaw DDR4 3200Mhz / HP Mellanox ConnectX-2 10 GbE PCI-e G2 Dual SFP+ Ported Ethernet HCA NIC / 9 Drives total 29TB - 1 4TB seagate parity - 7 4TB WD Red data - 1 1TB laptop drive data - and 2 240GB Sandisk SSD's cache / Headless
Why did I buy this server: OS unRAID v. 6.9.0-beta25 / Dell R710 enterprise server with dual xeon E5530 / 48GB ecc ddr3 / Dell H310 6Gbps SAS HBA w/ LSI 9211-8i P20 IT / 4 450GB sas drives / headless
Just another server: OS Proxmox VE / Dell poweredge R410
https://linustechtips.com/topic/840961-first-build-not-working/#findComment-10497490
Just to be safe ...
1. 4/8 pin EPS/ATX power is pluged in? (I guess so, since normaly this would result in a boot loop). GPU power cables plugged in (correctly? just check and reseat all power plugs).
2. Did you tried your RAM sticks in a different slot? Also try one stick at a time in each slot!
3. You didn't forget to place the mainboard standoffs correctly aren't you? Any unnecessary standoff need to get removed!
4. Did you tried different display cables, in different slots in your monitor/GPU?
5. Does your monitor turn on without any display input (does it even start? can you get to the OSD menu) maybe the monitors PSU isn't working.
6. Try to start the PC with as less USB devices plugged in as possible, unlikely but sometimes some devices cause issues on startup.
And.
7. Are you sure the GPU is working, it's a used one I guess and if you just brought it from someone he might ripped you off. (try a different GPU)
https://linustechtips.com/topic/840961-first-build-not-working/#findComment-10504725
On 02/10/2017 at 8:56 AM, Narnash said:
Just to be safe ...
And.
I got it working, had to re-install the CPU. It wasn't fully installed and came out when I took the fan off. Problem is I don't have any thermal paste so really need to get hold of some. Otherwise, it's all working beautifully now.
https://linustechtips.com/topic/840961-first-build-not-working/#findComment-10522106
