Help me to build PC!
Go to solution Solved by DocSwag,
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($195.89 @ OutletPC)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard  ($73.98 @ Newegg)
Memory: Team - Dark 16GB (2 x 8GB) DDR4-3000 Memory  ($134.99 @ Newegg)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive  ($77.99 @ SuperBiiz)
Storage: Western Digital - RE4 1TB 3.5" 7200RPM Internal Hard Drive  ($41.85 @ Amazon)
Video Card: Zotac - GeForce GTX 1070 8GB Mini Video Card  ($399.89 @ Amazon)
Case: NZXT - S340 (Black) ATX Mid Tower Case  ($64.99 @ SuperBiiz)
Power Supply: EVGA - SuperNOVA G3 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($74.98 @ Newegg)
Total: $1064.56
Generated by PCPartPicker 2017-09-30 10:30 EDT-0400
Hello everyone! I really need your help to build a PC for around 1,000$ - 1,200$.I need 8GB RAM with 2133 or 2400 Mhz,because I don't open a lot of softwares at the same time, therefore i don't need a lot of RAM.The main goal of my PC is just to play sometimes games like:
Tom Clancy's Ghost Recon: Wildlands
MASS EFFECT™: ANDROMEDA
  and so on.So my questions are:
What CPU should I buy?I heard i7 is better than Ryzen for gaming and it's a bit expensive,but it's worth.Also I heard Intel CPU + NVIDIA GPU is better than Intel CPU + AMD GPU (Intel + NVIDIA are compatible).
What Motherboard should I buy? I have 0 knowledge about motherboards,so i need you guys to help me about that.
What video card should I buy?I really don't need video cards like GTX 1080,it's just too much for me.I believe there are way cheaper video cards which are good enough to run games from 2k16 or 2k17.
About cooling system,I heard Cooler Master is big deal since it's cheap and good at the same time.Also I will buy SSD,because I heard PCs are way faster if they have SSD.
About Sound card/HDD/Power supply,I really have no idea!
https://linustechtips.com/topic/840908-help-me-to-build-pc/
that's a myth. an AMD GPU will work just fine with intel CPUs and nvidia cards will run on AMD CPUs.
i recommend the 1050ti - sadly, there is almost nothing left between the 1050ti and 1080 that is not overpriced or out of stock right now. if you can find a 6gb 1060 for a good price then take it. or buy a used 980.
finding 1060/1070 equivalent AMD cards for a good price is almost impossible at the moment.
https://linustechtips.com/topic/840908-help-me-to-build-pc/#findComment-10497085
-Ryzen 7 is worse than i7 for gaming, yes, but ATM I consider Ryzen 5 better than i5 for gaming
-Intel CPU+Nvidia GPU being "more compatible" is completely false
-For cooler master you just hear of them because of the 212 evo, which isn't really worth buying anymore.
I'll try making up a list right now.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/840908-help-me-to-build-pc/#findComment-10497101
I would go with Ryzen at this point, maybe a Ryzen 3 or Ryzen 5. It is cheaper.
Go with an overclockable board as you may not start overclocking right away but that way you can start when you feel ready.
Me personally I would get a used card like a 980ti or a used 1070, it will be cheaper in the long run. I have a GTX 980 and it runs GTA on highest settings at 70+ fps and higher most times (that is with FXAA [or MSAA I can't remember] on x8).
For the CPU cooler just go with the stock cooler then when you want to overclock get a beefier cooler.
Go with nzxt for 120mm or 140mm fans since you're just starting out, they are pretty quite but not noctua quite. Case wise, go with any case that fits your style. Make a list of what you need and then a list of what you want. Most of the time you don't need that $150 ATX Full Tower, (rookie mistake I made). There is nothing wrong with MATX and a smaller case.
For storage I would do a 1tb hdd and leave it at that. If you really want an ssd than get a 240gb ssd and the 1tb hdd. You don't need a sound card, and get a 80 Plus Gold power supply. PCPARTPICKER is your friend.
Instructions for frustration management:
1) Sit at desk.   2) Repeatedly slam forehead against desk.
I never said I was smart, just smart enough to be dangerous.
ORLY?
……..'|:::::::,': : : : : : :_„„-: : : : : : : : ~--„_: |'
………|::::::|: : : „--~~'''~~''''''''-„…_..„~''''''''''''¯|
………|:::::,':_„„-|: : :_„---~: : :|''¯¯''''|: ~---„_: ||
……..,~-,_/'': : : |:    ͡° ͜ʖ ͡°) : |: : : :|:  ( ͡° ͜ʖ ͡°)): \..|
……../,'-,: : : : : ''-,_______,-'': : : : ''-„_____|
………',:': : : : : : : : : : : : :,-'__: : : :_',: : : : ;: ,'
……….'-,-': : : : : :___„-: : :'': : ¯''~~'': ': : ~--|'
………….'|: \: : : : : : : : -,„_„„-~~--~--„_: :: |
You have been visited by the propane god, I tell ya hwat. Repost this on 5 more profiles or Hank Hill will bring the propain.
- credit to, @Cinnabar Sonar
https://linustechtips.com/topic/840908-help-me-to-build-pc/#findComment-10497103
Total: $1064.56
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/840908-help-me-to-build-pc/#findComment-10497124
