OK, so i have this great idea for a way to control my room. I have a harry potter remote control wand (Link at the bottom) and i want to try and use it to control my philips hue lights. My idea is beucase the wand works with IR i point the wand at the Logitech harmony hub and it blasts out a singal to the philips hue bridge and thus my lights turn on.
Is this a crazy idea or would it work
Harry Potter Wand (https://www.amazon.com/dp/B00FXMDRZK/ref=asc_df_B00FXMDRZK5193336/?tag=hyprod-20&creative=395033&creativeASIN=B00FXMDRZK&linkCode=df0&hvadid=194024095585&hvpos=1o1&hvnetw=g&hvrand=5782725677349068604&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9012089&hvtargid=pla-314762759648)
https://linustechtips.com/topic/840800-magic-wand-room-control/
If you can program the wand to give the correct IR for turning the lights on and off, it should work.
Desktop benching:
https://linustechtips.com/topic/840800-magic-wand-room-control/#findComment-10496254
But does the logitech hub take ir control or bluetooth. The wand works by replicating an ir signal sent out by a remote. My goal is to program the lights on button on the remote, program the wand to shoot out that ir signal and then point it at the hub.
https://linustechtips.com/topic/840800-magic-wand-room-control/#findComment-10496259
Just now, valdyrgramr said:
http://www.logitech.com/en-us/product/harmony-hub
Not sure.  Has the info, but you might wanna ask the maker.
I have tried, i got the same answer every time. Logitech Harmony Hub only works with the logitech Harmony remote and Logitech Harmony App. So not very helpful
https://linustechtips.com/topic/840800-magic-wand-room-control/#findComment-10496270
Just now, Legendarypoet said:
This sounds like something IFTTT could potentially handle. Sending an IR signal to something that can then tell IFTTT to turn on or off the lights. Just a thought. Idk if the Harmony hub can accept and transmit signals in the way you're wanting it to.
What could i use to interface with IFTTT that takes ir
https://linustechtips.com/topic/840800-magic-wand-room-control/#findComment-10496295
Well, they did answer. If it works, they haven't tested or verified it.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/840800-magic-wand-room-control/#findComment-10497234
