1 minute ago, Legendarypoet said:
Wow. Blast from the past.
Didn't Blackberry have special plans for data? I know they all got phased out.
Have you tried the latest software build for that phone?
Just shooting in the dark here. Haven't touched a Blackberry since 2011.
I trying that now.
https://linustechtips.com/topic/840786-blackberry-help/#findComment-10496104
Yeah, from what I remember Blackberry phones used to have separate data plans than regular phones. I imagine that's the issue you're running into. You're not missing out on anything. Any kind of browsing on a device of that era is absolutely horrible.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/840786-blackberry-help/#findComment-10496118
i used a blackberry in 2014 (broke my phone so went back to my bold for a while) and i used browsing native through verizon's data plan. just popped my sim in a
Main Rig | Personal Build | Windows 10 | R7 2700x 3.7~4.3ghz | ASUS ROG Strix B450-I | 16gb DDR4 3200mhz | GTX 1080 FE | Coolermaster Elite 130 | Corsair H60 | WD Blue SN500 500GB NVMe SSD + 1tb WD Green HDD + 1tb WD Blue HDD
Laptop | HP m6-w102dx | Windows 10 | i7-5500u 2.4~3.0ghz | 8gb DDR3L | GT 930m 2gb| 120gb Sandisk SSD
Phone | Pixel 3 | Verizon | 64gb
https://linustechtips.com/topic/840786-blackberry-help/#findComment-10496157
Yup. This phone is from 2010. Different era.
https://linustechtips.com/topic/840786-blackberry-help/#findComment-10496164
I'm not sure if you've done this or not, but have you tried manually putting in the APN information?
https://linustechtips.com/topic/840786-blackberry-help/#findComment-10496174
rip my bad. i mis-entered the model number on google lol
https://linustechtips.com/topic/840786-blackberry-help/#findComment-10496179
2 minutes ago, Master Jorn said:
Not saying that I DONT know what my apn information is, but could you tell me how to get it, just to jog my memory?;)
Not really. Google it? I had to input on my Zenfone to get any kind of data to work.
It's not secret, and it's not specific to you, it's just network information.
Google *your network* APN and it should pop up. For example, here's the one I use.
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-set-up-data-APN-on-my-smartphone/td-p/3
https://linustechtips.com/topic/840786-blackberry-help/#findComment-10496191
