So i am building a pc for a friend and I got him a R5 1600x and paired it with a msi b350 gaming pro carbon. It is not booting with this ram:
Patriot Viper Elite 16GB (2 x 8GB) DDR4 2666MHz
https://www.newegg.com/Product/Product.aspx?Item=N82E16820225075&ignorebbr=1&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Memory+(Desktop+Memory)-_-N82E16820225075&gclid=CjwKCAjw3rfOBRBJEiwAam-GsKEf-yelcO_QU4UC-mUDvsT1l8l1pg_Vwv7qcKEJK1ZTW6oo0QRIKBoCXM8QAvD_BwE&gclsrc=aw.ds
I used some of my own to install windows and do a bios update but the thing is not booting with the new ram i purchased.
Any ideas??
https://linustechtips.com/topic/840732-ryzen-5-memory-issues/
Any ideas??
Did you check the ram on another PC? It's entirely possible, albeit unlikely, you got a couple of dead sticks.
https://linustechtips.com/topic/840732-ryzen-5-memory-issues/#findComment-10495620
Any ideas??
This is the third time I've heard of this Patriot Viper ram today. Maybe I'm just blind and never saw it. It is on Patriot's list of Ryzen compatible kits.
Patriot Publishes List of AMD Ryzen Compatible DIMMs: Up to DDR4-3400, 64 GB
Does it post? Are you able to get into the bios to see the timings the board chooses by default?
CPU: Ryzen 5 5600x  Board: Asus PRIME X570-P  Ram: G.Skill Ripjaws V Series 16GB (2x8) DDR4-3000  Case: Fractal Design Define S
GPU: NVIDIA GeForce RTX 3070  SSD: HP EX950 1 TB M.2-2280 NVME  HDD: Seagate Barracuda 3TB 3.5" 7200RPM
PSU: SeaSonic FOCUS Plus Platinum 750W  Cooler: Noctua NH-U12S SE-AM4  Monitor: Viotek GFT27DB 27.0" 2560x1440 144 Hz
https://linustechtips.com/topic/840732-ryzen-5-memory-issues/#findComment-10495948
No it doesn't post, the most progress I made was by swapping in some ripjaws and changing timings then swap back in the patriot ram. It would turn on and off by itself for a while then hang I tried to put in the timings from the spec sheet but no luck
https://linustechtips.com/topic/840732-ryzen-5-memory-issues/#findComment-10495985
Short of returning it and purchasing something known to work off QVL or some Samsung B-Die, the only thing I can think of would be to try your ripjaws method of changing the timings, choosing something incredibly loose, and lower frequency. 2133, 18-18-18-38, 2T command rate, 1.4v dram voltage, 1.1v CPU NB Voltage (soc voltage on other boards).
You may know this already, but I'll say it anyways. You are putting them in slots DIMMA2 and DIMMB2, right? I'm probably grasping at straws here. The rebooting is normal though, just Ryzen boards' attempts to "learn" sub-timings capable of posting. Other than resetting cmos, or giving it 5-10 minutes to post, I'm out of ideas.
https://linustechtips.com/topic/840732-ryzen-5-memory-issues/#findComment-10496011
