I'm going to build a custom loop, there is not many upgrades i can do hardware wise anymore with a 7700k and 1080 ti. So I seek advice here. What would be the best rad/fan setup in a Evolv ATX TG? I'm willing to slightly mod the case  but I'm not very fond of modding the front or top panels. I know this case has pretty bad airflow but I am willing to trade higher temps for looks. As I understand the top is the most restrictive, and as such would it be best to put only a 360mm rad in the front with push pull and no rads in the top or go with only a top rad in push pull to have better airflow into the case?
As I said I am ready to take 5C higher temps if It means I don't have to cut in my front or top panel. Though I will drill extra holes in the basement for the pump if I go with a front rad.
The versions I have thought of so far is either a 240mm push/pull front and a 360mm top OR just a thicker 360 front with push pull.
Thanks in advance.
(I already know of the spacing mods)
Specs:
7700k
1080 Ti Poseidon
Asus z270-F
EDIT: I will most likely be delidding my 7700k in the near future
Desktop:
7700k 4.5GHz @ 1.1130V
Noctua NH-D15s
Asus ROG Z270-F
16GB Vengance RGB @ 3000MHz
Asus GTX 1080 Ti Poseidon
2xKingston A400 480GB in Raid 0
Corsair RM850 850W
Phanteks Evolv ATX TG
Screens:
Benq XR3501
Asus V247H
https://linustechtips.com/topic/840675-evolv-atx-tg-custom-loop/
8 minutes ago, Dreaper said:
What's the point in buying a 180$ case if I'm gonna ruin the main selling point? I didn't want to ruin the looks of the case if at all possible, even if I get 5-10C higher temps or have to run the fans at slightly higher rpm.
Desktop:
Noctua NH-D15s
Asus ROG Z270-F
Corsair RM850 850W
Screens:
Benq XR3501
Asus V247H
Believe me, the difference is much bigger. If it was only 5C, so many people wouldn't bother screwing up their cases looks.
Which mod do you mean? Blocking of the top openings of the bracket?
What you also can do is put spacers on the front panel, making it sit more forward to make the front openings a bit bigger. Also saw people remove the mesh on the top openings to lower airflow restriction and even cut away the fins of the top panel in the back. Some leave their top panel unscrewed, and not clicked into place which also might help.
Do you even read bro. He mentioned multiple times he doesn't want to mess with the looks of his case.
If it were me, I'd put a thick 280mm in the front and a 240/280 up top. Temps should be reasonable with your system in that set up.
Obviously there are better cases for airflow and mods you can do but nothing without sacrificing the aesthetic of the EVOLV pretty significantly.
Like you said though, you're not too bothered about temps/acoustics so keep your case as is and run a 240/thick 280 or 280/thick 280 and you'll be good.
Intel Core i7-4790k @ 4.7GHz | Asus Maximus VII Hero | NZXT Kraken X61 | 2x8GB Corsair Vengeance Pro(Red) @ 1866MHz | 2TB Seagate Barracuda | 250GB Samsung 850-EVO | 2- way SLI Asus Strix GTX 970's @ 1500MHz | EVGA 750W G2 | NZXT H440(black/red) | 3x120mm Sharkoon Shark Blade fans(red) | 3x140mm Be Quiet! Pure Wings 2 fans |
The spacer mods and the removal of the mesh don't affect the look that much so I have indeed thought of doing those. Most mods are fine as long as they don't cost too much (After a loop I would be basically dry on cash) and they don't ruin the looks. I knew the case compromised airflow and as I stated I would be ready to run my fans a little faster. I would most likely be running a bunch of Noctua NF-F12 fans since I already have 4 of those.
Desktop:
Noctua NH-D15s
Asus ROG Z270-F
Corsair RM850 850W
Screens:
Benq XR3501
Asus V247H
One mod I have thought of doing is so you can fit fans above the fan bracket which would allow me to run a 360 up top and a 45mm 240 front with push pull. I'm very interested in the idea of push/pull setups as that would help overcome some of the restriction with a rad.
Desktop:
Noctua NH-D15s
Asus ROG Z270-F
Corsair RM850 850W
Screens:
Benq XR3501
Asus V247H
It's not like your system will throttle with that setup, a lot of people still do custom loops without modding their panels.
I'm also planning for a custom loop in my case and chose to mod the panels for optimal performance. I didn't want big holes in my case, so came up with this design (openings are about the same size as the original top vents).
  Hide contents
That is a mod I would actually do. Did you do it yourself? How was it done? That doesn't impact the looks as heavily as some things i have seen.
Desktop:
Noctua NH-D15s
Asus ROG Z270-F
Corsair RM850 850W
Screens:
Benq XR3501
Asus V247H
No, I had it done by a local company. Just told them what I wanted and they cut it for me. However with the cost of the mod, the total price of the case almost got doubled, so it's not that cheap to get something custom designed and cut.
Ok, getting something like that done professionally would be very difficult here i Sweden where I live. So I'll either not do any cutting or some very simple mods to help a little bit
Desktop:
Noctua NH-D15s
Asus ROG Z270-F
Corsair RM850 850W
Screens:
Benq XR3501
Asus V247H
So I'm posting a second thread about this, since only one person actually posted something related to my question.
My question goes: How should I place my loop in the Evolv atx TG if I'm watercooling my 7700k and a 1080 Ti Poseidon. I'm NOT asking for mods to help airflow, I am already aware of those problems with this case. How much rad space should i get?  If I can keep the looks of the case and have to deal with slightly higher temps I'm fine with that.
Some options I have thought of are 360mm Push/pull front and a 240mm top, or possibly just a thicker 360 front with push pull.
I'm NOT asking for mods and replacement front panels!
Thanks in advance
Desktop:
Noctua NH-D15s
Asus ROG Z270-F
Corsair RM850 850W
Screens:
Benq XR3501
Asus V247H
You should bump the old thread, not make a new one.
For really good performance I'd go 360 front + thin 240 top or if that's too tight maybe a 120 on the rear or 2x 240s, one thick one thin
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
17 minutes ago, Himommies said:
I would reccomend a thin top and front 240 mm rad
Thanks for answers that are actually relevant to the question :)
Desktop:
Noctua NH-D15s
Asus ROG Z270-F
Corsair RM850 850W
Screens:
Benq XR3501
Asus V247H
