Help
Go to solution Solved by johndms,
4 minutes ago, Gpuprodamnn said:
I am sorry, I may sound like a complete idiot but on AMD site it says that the ryzen 5 1600 supports 2667 MHz ram max therefore the 2666 kit seems the best. I have no problem paying more for the ram but I just wanted to know if it will change anything. Thanks!
2666 will be just fine with your build, but I doubt you'll find the Samsung B-Die everyone loves at less than 3000MHz. The Patriot Viper Elite kit mentioned earlier appears to be Ryzen compatible. I've not heard of that kit before, so I can't offer my opinions on it.
I often share a particular YouTube video that shows benchmarks comparing 2666 vs 3200 on a Ryzen 5 1600. It gives fairly good evidence that suggests the difference between 2666 and 3200 isn't as impressive as people may want you to believe. Don't misunderstand me though, there is a difference, but not enough (in my opinion) to warrant spending more than 10% extra on 3200, if you can get 3000, or 2666 for significantly less. https://www.youtube.com/watch?v=mOWx5LH4uBo
You'll hear many boasting, "Ryzen performs SO MUCH BETTER and gives MASSIVE fps boosts while gaming using high frequency ram," and a lot of talk of Infinity Fabric. While the claims of performance gains regarding Infinity Fabric are true, many tend to blow it all out of proportion. This, unfortunately, leads people to believe they MUST purchase 3200MHz or higher Samsung B-Die because anything less will severely hinder their system. I'll provide a link and allow you and everyone else to form your own opinions. http://forum.asrock.com/forum_posts.asp?TID=4963&title=ryzen-ram-frequency-and-gaming
So i will be building my first gaming Pc ever. Didn’t want to spend too much since I don’t really have enough time for gaming so I think a 1000$ PC will get the job done. Already bought gtx 1060 6gb, Ryzen 5 1600, asrock ab350 pro4 ATX and a middle tower case with 3 fans. What else should I get? Maybe the Evga 600w, 1TB HDD, 240gb SSD M.2 and 16gb of ram 2666mhz but what brand or what is compatible with what I already got. Thanks!
  • CPU
    Ryzen 5 1600 OC 3,7ghz
  • Motherboard
    ASrock AB350 Pro4 ATX
  • RAM
    A-Data 2666mhz upgraded to Corsair LPX 2x8gb 3000mhz
  • GPU
    GTX 1060 6gb
  • Case
    Segotep Chariot TF
  • Storage
    1TB HDD, 240gb M.2 Intel NVMe SSD
  • PSU
    Evga 600w B+
  • Display(s)
    Samsung Full HD 24' Free sync
  • Cooling
    3x 120mm case fans
  • Keyboard
    Razer BlackWidow Chroma V2
  • Mouse
    Razer DeathAdder Elite
  • Sound
    Razer Kraken Pro
  • Operating System
    Windows 10 Pro
https://linustechtips.com/topic/840496-help/
I recommend the EVGA 550 G2. Or the 650 G2 if that fits your budget. Both are extremely solid PSUs that will last you for years.
A SATA 500GB SSD would provide more value for the money than a 240GB m.2 drive. Speed difference is basically imperceptible for most users as far as gaming is concerned.
As for RAM and Ryzen, it can be a bit of effort to get RAM optimized. Unless you get Samsung B-die RAM (this can be expensive), your mileage will vary. I recommend doing some research on this topic. This is a good place to start.
A 3000 Mhz kit is highly recommended though, as Ryzen will benefit greatly from that compared to 2666. Thanks to recent microcode updates from AMD, RAM compatibility is a lot better and 2933 is usually always obtainable with most 3000 Mhz RAM, so long as you don't get a cheap kit.
New Build (The Compromise): CPU - i7 9700K @ 5.1Ghz Mobo - ASRock Z390 Taichi | RAM - 16GB G.SKILL TridentZ RGB 3200CL14 @ 3466 14-14-14-30 1T | GPU - ASUS Strix GTX 1080 TI | Cooler - Corsair h100i Pro | SSDs - 500 GB 960 EVO + 500 GB 850 EVO + 1TB MX300 | Case - Coolermaster H500 | PSUEVGA 850 P2 | Monitor - LG 32GK850G-B 144hz 1440p | OSWindows 10 Pro.
Peripherals - Corsair K70 Lux RGB | Corsair Scimitar RGB | Audio-technica ATH M50X + Antlion Modmic 5 |
CPU/GPU history: Athlon 6000+/HD4850 > i7 2600k/GTX 580, R9 390, R9 Fury > i7 7700K/R9 Fury, 1080TI > Ryzen 1700/1080TI > i7 9700K/1080TI.
Other tech: Surface Pro 4 (i5/128GB), Lenovo Ideapad Y510P w/ Kali, OnePlus 6T (8G/128G), PS4 Slim.
https://linustechtips.com/topic/840496-help/#findComment-10493121
Asrock usually got compatibility list for supported ram/cpu for their mainboards on the mainboard specific site.
If you don't look at that, I found ADATA ram usually working fine for many years now. No matter the brand of board.
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
https://linustechtips.com/topic/840496-help/#findComment-10493123
NVMe SSDs and SATA SSDs perform similarly as a boot drive. No need to go for expensive NVMe ones. Keep in mind that there are SATA SSDs that fit in M.2 slots, so dont pay more for the same thing.
Desktop benching:
https://linustechtips.com/topic/840496-help/#findComment-10493140
try this:
Memory: Patriot - Viper Elite 16GB (2 x 8GB) DDR4-3000 Memory  ($134.99 @ Newegg)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive  ($77.99 @ SuperBiiz)
Storage: Toshiba - P300 1TB 3.5" 7200RPM Internal Hard Drive  ($41.99 @ Amazon)
Power Supply: BitFenix - Whisper M 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.59 @ SuperBiiz)
Total: $334.56
Generated by PCPartPicker 2017-09-29 07:48 EDT-0400
https://linustechtips.com/topic/840496-help/#findComment-10493143
  • CPU
  • Motherboard
  • RAM
  • GPU
    GTX 1060 6gb
  • Case
    Segotep Chariot TF
  • Storage
  • PSU
    Evga 600w B+
  • Display(s)
  • Cooling
    3x 120mm case fans
  • Keyboard
  • Mouse
  • Sound
    Razer Kraken Pro
  • Operating System
    Windows 10 Pro
https://linustechtips.com/topic/840496-help/#findComment-10493148
4 minutes ago, herman mcpootis said:
try this:
Total: $334.56
I hate cables, could you please come up with a M.2 SSD?
  • CPU
  • Motherboard
  • RAM
  • GPU
    GTX 1060 6gb
  • Case
    Segotep Chariot TF
  • Storage
  • PSU
    Evga 600w B+
  • Display(s)
  • Cooling
    3x 120mm case fans
  • Keyboard
  • Mouse
  • Sound
    Razer Kraken Pro
  • Operating System
    Windows 10 Pro
https://linustechtips.com/topic/840496-help/#findComment-10493152
Thanks for the info, didn’t know that.
  • CPU
  • Motherboard
  • RAM
  • GPU
    GTX 1060 6gb
  • Case
    Segotep Chariot TF
  • Storage
  • PSU
    Evga 600w B+
  • Display(s)
  • Cooling
    3x 120mm case fans
  • Keyboard
  • Mouse
  • Sound
    Razer Kraken Pro
  • Operating System
    Windows 10 Pro
https://linustechtips.com/topic/840496-help/#findComment-10493153
Yea, it does but I figured it’s only compatible with the mobo itself not the processor.
  • CPU
  • Motherboard
  • RAM
  • GPU
    GTX 1060 6gb
  • Case
    Segotep Chariot TF
  • Storage
  • PSU
    Evga 600w B+
  • Display(s)
  • Cooling
    3x 120mm case fans
  • Keyboard
  • Mouse
  • Sound
    Razer Kraken Pro
  • Operating System
    Windows 10 Pro
https://linustechtips.com/topic/840496-help/#findComment-10493156
there's this, but it costs more. it's not much extra cables for a sata ssd, a PSU sata cable has multiple connectors and the sata cable isn't much to manage anyways.
https://pcpartpicker.com/product/KXkwrH/crucial-mx300-275gb-m2-2280-solid-state-drive-ct275mx300ssd4
https://linustechtips.com/topic/840496-help/#findComment-10493165
CPU: Ryzen 5 5600x  Board: Asus PRIME X570-P  Ram: G.Skill Ripjaws V Series 16GB (2x8) DDR4-3000  Case: Fractal Design Define S
GPU: NVIDIA GeForce RTX 3070  SSD: HP EX950 1 TB M.2-2280 NVME  HDD: Seagate Barracuda 3TB 3.5" 7200RPM
PSU: SeaSonic FOCUS Plus Platinum 750W  Cooler: Noctua NH-U12S SE-AM4  Monitor: Viotek GFT27DB 27.0" 2560x1440 144 Hz
https://linustechtips.com/topic/840496-help/#findComment-10493171
Thanks! Also you told me about the 3000mhz memory, but on the AMD site it says that ryzen 5 1600 only supports 2667 MHz. Am I missing something ?
  • CPU
  • Motherboard
  • RAM
  • GPU
    GTX 1060 6gb
  • Case
    Segotep Chariot TF
  • Storage
  • PSU
    Evga 600w B+
  • Display(s)
  • Cooling
    3x 120mm case fans
  • Keyboard
  • Mouse
  • Sound
    Razer Kraken Pro
  • Operating System
    Windows 10 Pro
https://linustechtips.com/topic/840496-help/#findComment-10493172
you can set the memory to 2933mhz with the motherboard bios.
https://linustechtips.com/topic/840496-help/#findComment-10493176
You've been given excellent suggestions for PSUs, but they're fairly high end and costly. I'd like to recommend an equally good quality PSU that's slightly cheaper. Just for the sake of having options. The Corsair CX550M would do nicely.
https://linustechtips.com/topic/840496-help/#findComment-10493180
Thanks! I will be getting 3000mhz for memory probably from Corsair or the G.Skill Ripjaws V. Also I saw that you have almost the exact same build, never mind that gtx 1070 :D. How is it?
  • CPU
  • Motherboard
  • RAM
  • GPU
    GTX 1060 6gb
  • Case
    Segotep Chariot TF
  • Storage
  • PSU
    Evga 600w B+
  • Display(s)
  • Cooling
    3x 120mm case fans
  • Keyboard
  • Mouse
  • Sound
    Razer Kraken Pro
  • Operating System
    Windows 10 Pro
https://linustechtips.com/topic/840496-help/#findComment-10493182
Ryzen's memory controller supports 2666 by default. However it will work with faster RAM.
Any speed over that is considered a memory overclock, which will usually work with Ryzen depending on many factors - such as your motherboard, BIOS, RAM, and (to a lesser extent) your PSU. Enabling a DOCP profile in your BIOS can get you a quick and basic memory overclock which will be of benefit to your performance, though its result pale compared to manually optimized timings and speed.
For example my 1700, which also technically supports 2666 by default, works just fine with my very well binned 3200 Mhz RAM at very highly optimized timings (14-14-14-28 at 1T command rate). That being said... my RAM cost me $205, so I had to pay a hefty premium for that.
https://linustechtips.com/topic/840496-help/#findComment-10493185
Ohh, I don’t mind spending more as long as it’s a quality product.
  • CPU
  • Motherboard
  • RAM
  • GPU
    GTX 1060 6gb
  • Case
    Segotep Chariot TF
  • Storage
  • PSU
    Evga 600w B+
  • Display(s)
  • Cooling
    3x 120mm case fans
  • Keyboard
  • Mouse
  • Sound
    Razer Kraken Pro
  • Operating System
    Windows 10 Pro
https://linustechtips.com/topic/840496-help/#findComment-10493186
I'm satisfied with it for the most part. The kit of ram I have, F4-3000C15D-16GVKB is Hynix M-Die Single Rank and works perfectly on my ASRock board after bios update. I've even overclocked it to 3200MHz at 16-18-18-18-36 timings at 1.4v. I tend to keep it at XMP 2933 though because the performance difference isn't enough, in my opinion.
The board is good, but I'd probably not choose it again if I could go back. It's fine with overclocking to 3.8GHz at 1.35v, but it lacks certain bios settings for extra overclocking options. It has no LLC options for CPU voltage control. During load, my 1.35v has dropped to as low as 1.256v (massive vdroop). You also can't change SOC Voltage (used for memory overclocking stability) in the bios. The ASRock AB350 Pro4 is your basic, no-thrills, B350 budget oriented board. It'll overclock some, but don't expect to break 4GHz.
https://linustechtips.com/topic/840496-help/#findComment-10493191
Adding more to my comment. If I could go back and spend a bit more.. I'd purchase F4-3000C14D-16GVK for $15usd more as it contains Samsung B-Die. Often considered more Ryzen-friendly and overclocks easier/better.
https://linustechtips.com/topic/840496-help/#findComment-10493193
Didn’t even think to overclock right now, i think the base speed is enough for now. I will definitely push its limits if I can’t play a certain game, tho that game doesn’t exist right now.
  • CPU
  • Motherboard
  • RAM
  • GPU
    GTX 1060 6gb
  • Case
    Segotep Chariot TF
  • Storage
  • PSU
    Evga 600w B+
  • Display(s)
  • Cooling
    3x 120mm case fans
  • Keyboard
  • Mouse
  • Sound
    Razer Kraken Pro
  • Operating System
    Windows 10 Pro
https://linustechtips.com/topic/840496-help/#findComment-10493194
