Kernel Power 41 - IEC Extension Cable?
Hello,
since I moved to a new house I've started getting Kernel Power 41 (63) critical errors (no BSoD/RSoD, just a pure red screen with no text on it).
I check my PSU modular cables and they all look fine. However, I must admit that my PC is connected to a surge protected power strip, which is connected to another power strip along with the internet router and monitor. I borrowed the second power strip (non-surge protected) from one of my housemates and it looks very cheap, and I think that the problem might be caused by it as it does not deliver enough power to my system at times.
Since I cannot move the internet router due to the fiber cable, and I cannot move the desk either, I was thinking of buying a IEC extension cable to plug the PC into a further away socket that is not shared by any other appliance. However, my cable is not long enough, and I was thinking of buying this (see picture). In this way the PC would be connected in this way: Socket > UK to EU adapter > APC surge protector  power strip (only PC connected to it) > IEC extension > original PSU cable > case cable (the Node 202 has a cable extension inside it before it reaches the PSU) > PSU
Is it safe to use IEC extension cables? Do you think this MIGHT fix the Power Kernel problem?
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/840474-kernel-power-41-iec-extension-cable/
2 hours ago, jonnyGURU said:
What PSU?
Corsair SF450
I am now using that cable extension, seems to be working fine. But if you have any opinion to share, I would be glad if you shared it.
Unraid Server
