Does anyone here run 1.25/1.35V ram, and have you run into issues with stability/performance? I'm looking at a particular crucial kit:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148663
Another good point would be how much less power does it draw
I do not feel obliged to believe that the same God who has endowed us with sense, reason and intellect has intended us to forgo their use, and by some other means to give us knowledge which we can attain by them. - Galileo Galilei
Build Logs: Tophat (in progress), DNAF | Useful Links: How To: Choosing Your Storage Devices and Configuration, Case Study: RAID Tolerance to Failure, Reducing Single Points of Failure in Redundant Storage , Why Choose an SSD?, ZFS From A to Z (Eric1024), Advanced RAID: Survival Rates, Flashing LSI RAID Cards (alpenwasser), SAN and Storage Networking
https://linustechtips.com/topic/840-low-voltage-ram/
The Samsung 30nm ram kits are excellent and run at that low of voltage. Though, the difference between 1.35v and 1.5v on ram is very small in terms of power draw.
My Rig:
  • CPU: 1090T@4.1ghz
  • GPU: Gigabyte 7870
  • MOBO: Crosshair Formula V
  • RAM: 8GB 1333mhz
  • PSU: 650w corsair HX
  • SSD: 120GB Kingston HyperX
  • Sound card: Asus Xonar DX
https://linustechtips.com/topic/840-low-voltage-ram/#findComment-10749
The Samsung 30nm ram kits are excellent and run at that low of voltage. Though' date=' the difference between 1.35v and 1.5v on ram is very small in terms of power draw.[/quote']
Agreed, these little suckers sip power and thy can overclock like mad. My neighbors and I got them to 2400mhz but I don't remember the voltage.
https://linustechtips.com/topic/840-low-voltage-ram/#findComment-10791
Wow, that kit looks exactly like the Samsung wonder ram, but at a much higher price. Go with Samsung 30nm.
Are these the ones you're referring to?
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147096
I don't know if they have 8GB sticks, which is what I need
https://linustechtips.com/topic/840-low-voltage-ram/#findComment-11475
