Gigabit WAN Upgrade- Wierd Issues
Solved by brwainer,
The cable that was labeled as (#3-#4) plugs directly in to the wall socket?
visually inspect the wall socket to see if one of the pins is damaged. Possibly with the cable you used for testing, it makes a connection, but with the actual cable you are using it does not.
Featured Topics
Hichem922 ·
Posted in Troubleshooting1 -
GanjajoggiBig ·
2
220VoltsallCore ·
Posted in Storage Devices6 -
_t8r_ ·
Posted in Power Supplies3 -
