Im looking at a build for an ITX PC, however im a little unsure on the powersupply. I have a strict dimension limit of 140mm in length which severely limits my PSU options. I was looking at a 4770k with a Asus Z87 Deluxe I board with a 780TI graphics card. Plus 2 hard drives. Would a 500W gold rated PSU be enough for the build? The parts will probably be mildly overclocked, however not a complete overkill overclock just due to the CPU cooler size restraints.
Here was the PSU that I was looking at http://www.newegg.com/Product/Product.aspx?Item=N82E16817104173
Also what are your thoughts on the AURUM line of FSP powersupplies?
https://linustechtips.com/topic/83965-psu-for-itx-build/
go for seasonic g series with 550watt its 80plus gold certified and has 5 years warranty
https://linustechtips.com/topic/83965-psu-for-itx-build/#findComment-1143295
So unfortunately I cant go for the seasonic as its too long.
https://linustechtips.com/topic/83965-psu-for-itx-build/#findComment-1143326
Im not sure if a 450W is up to the tak of power a 780TI and 4770k though :/
I've seen people run a Titan and a 4770K with it, what the power requirements for the 780Ti is however I don't know. Either way you will not have huge headroom for overclocking. I didn't see however that you were gonna use the Lian-Li case, and if you're gonna use a case which has space for a regular sized ATX power supply you should of course just get one of those. The reason I went with the SFX power supply is because I'm going as small possible and building my own case.
https://linustechtips.com/topic/83965-psu-for-itx-build/#findComment-1143397
the thing is whith the case its very picky with the PSU, require it to be no longer then 140mm. Most ATX supplies run into 160mm. The FSP one I linked fits the requirements, however I have never had a personal experience with FSP group products.
https://linustechtips.com/topic/83965-psu-for-itx-build/#findComment-1143482
go for bitfenix prodigy it supports seasonic psu and gtx 780ti
https://linustechtips.com/topic/83965-psu-for-itx-build/#findComment-1143496
nope, thats why I posted it as a power supply question not a case question. I personally think the Prodigy looks like a cheap piece of junk.
I'm with you on that one, never been a big fan of the case, plus it's much larger than it needs to be.
As for FSP PSU's I have no personal experience, but it generally seems that the few people who are using them like them.
https://linustechtips.com/topic/83965-psu-for-itx-build/#findComment-1144004
Cant really comment on FSP's power supplies as I've never used them, but as another option, you could try the Silverstone ST60F-PS. Its a 600w 80+ Silver rated power supply, that also is fully modular, and is 140mm. It is a little pricey compared to the FSP you posted though.
Build LogsPCX - A HTPC/Low End Gaming PC in a Playstation 1 Chasis (90-ish% done) | Yamaha PC-350 (Computer in a RD-350 engine) --> Coming Soon | Mediocre Terrors: Yet Another Prodigy Build Log
https://linustechtips.com/topic/83965-psu-for-itx-build/#findComment-1147221
