Jayztwocents has everything you need, he's the goto guy for watercooling tips.
Main Rig
CPU: Ryzen 2700X
Cooler: Corsair H150i PRO RGB 360mm Liquid Cooler
Motherboard: ASUS Crosshair VII Hero
RAM: 16GB (2x8) Trident Z RGB 3200MHZ
SSD: Samsung 960 EVO NVME SSD 1TB, Intel 1TB NVME
Graphics Card: Asus ROG Strix GTX 1080Ti OC
Case: Phanteks Evolv X
Power Supply: Corsair HX1000i Platinum-Rated
Radiator Fans: 3x Corsair ML120
Case Fans: 4x be quiet! Silent Wings 3
https://linustechtips.com/topic/839608-tips-for-my-first-loop/#findComment-10483745
The result of hardline and flexible are the same but hardline, imo, looks so much more slick than flexible. If you have the money, then go for it.
"May your frame rates be high and your temperatures low"
I misread titles/posts way too often--correct me if I don't.
https://linustechtips.com/topic/839608-tips-for-my-first-loop/#findComment-10483768
hardine is much less convinient to maintain (pretty hard actually). i wouldn't recommend to new user but it does look sic. only thing you need to know is put the rez before the pump, otherwise filling is impossibly hard (some guy made that mistake and posted on the forums asking what was wrong last week).
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/839608-tips-for-my-first-loop/#findComment-10483911
