I need a little help
Does anyone knows where can i get microisb cable but without the rubber band that it is on it? Only data cable
I am thinking some thing like is in the senheizer go pro water proof mike
I can't found something on internet
Tnx
Kacper
Quote me so I can reply <3
https://linustechtips.com/topic/838968-micro-usb-cable-without-a-rubber/
Tnx
Kacper
Are you talking about the casing around the plug? Your going to have to custom make something like that but you can get solder on connectors like theses and just not install the snap together casing.
https://www.adafruit.com/product/1390
he wants cable without the casing - to make the cable slimmer to fit in a gopro case
@Gawron10001 a usb cable without proper shielding could be really bad if exposed to water
Photography / Finance / Gaming
6 hours ago, OLS said:
What do you mean by rubber band on it? o.O
Sorry, i had problem with naming. Casing on the cable
I know, it can go badly with water, i was thinking about putting on raw cable heatshrink tube so it will be waterproof again but i thought it won't work out. But i got better idea.
I will drill little holes where is usb plug, connect it and seal with hot glue. I know i won't be able to pull out camera again but it is Super cheap camera from tracer, it is sj4000 i belive. It will be working with raspberry pi zero and will be acting as camera bike, because this camer has broken navigation swithes and micro sd card port so it does not matter to me anymore.
I was thinking about it but i suck at soldering so i wouldn't even attepmt at this
Any way thanks guys for interest, and writte if u want to see the resoults
Tnx
Kacper
Tnx
Kacper
In that case something like this might interest you using flat flex cables:
https://aerialpixels.com/shop/audio-video-cables-accessories/ultra-thin-flexible-gopro-3-fpv-cable-audio-video/
