Hey, this is my first post please don't be rude.
I'm planning on building my first computer ever I already bought a Thermaltake core V1 and a  Rosewill Glacier 500w
I'm thinking about getting an Asus Strix z270i a mini itx with build in wifi and bluethooth, any suggestions?
Also I want to get the I5 6600k  and go with the stock fan since I'm not going to overclock is that ok?
16gb of ddr4 2400
and this video card https://pcpartpicker.com/product/jZJkcf/asus-geforce-gtx-1060-6gb-dual-video-card-dual-gtx1060-o6g
also an 120gb m.2 to boot but I'm not sure if they are all the same since I read something about b+g keys or something like that
a 1tb hhd and 250ssd for some programs and games
What do you think?
Any recomendation?
Sorry for the English I'm not a native speaker :c
https://linustechtips.com/topic/838914-mini-itx-first-build/
the 6600k doesn't come with a stock cooler, get a 1600 and itx b350 board instead. no need for a seperate m.2 ssd for a boot drive, just use obe 240gb ssd and be done with it.
https://linustechtips.com/topic/838914-mini-itx-first-build/#findComment-10476143
I5's are so, so bad dude.  Get an i7 7700 non k instead, the stock cooler will be able to cool it.
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/838914-mini-itx-first-build/#findComment-10476145
Like Damascus said, if you don't plan on overclocking go for a cheaper B250 motherboard and locked I7, it should be around the same price
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
https://linustechtips.com/topic/838914-mini-itx-first-build/#findComment-10476153
1 minute ago, pancho2596 said:
Is going to affect performance? I mean the 1600
The ssd sounds like a good idea since it's only a matter of seconds
The 1600 will be better, come with a stock cooler and run cooler.
https://linustechtips.com/topic/838914-mini-itx-first-build/#findComment-10476160
Sounds good, I'll be getting the B250 and the i7 7700 a friend told me that ulocked works better even if youn don't overclock is that real?
https://linustechtips.com/topic/838914-mini-itx-first-build/#findComment-10476163
Yes, itll run faster than a non k but im not too sure if the price bump is worth it.
Specs:
 Gaming PC: i5 3570, 16GB 1600MHz, GTX 780 3GB, Transcend 128GB, WD 500GB, Seagate 500GB, Thermaltake 600W Smart, S340 w/ RGB, Windows 10 Pro
 Server: Xeon E5 2650, 12GB 1600MHz ECC, 8400GS, WD 2TB + 1TB + 1TB, EVGA 500B 500W, Windows 10 Pro
 Laptop: Macbook Pro Retina 2013, i7 4558U, 8GB 1600MHz, Intel Iris Pro 1.5GB, Apple 256GB NVME, Mojave
 Internet: $70/month For 500/100, Actually get 525/102
https://linustechtips.com/topic/838914-mini-itx-first-build/#findComment-10476169
-snip-
https://linustechtips.com/topic/838914-mini-itx-first-build/#findComment-10476178
1 minute ago, Moress said:
CPU: Intel - Core i5-7600K 3.8GHz Quad-Core Processor  ($209.89 @ Amazon)
CPU Cooler: CRYORIG - C7 40.5 CFM CPU Cooler  ($26.99 @ Newegg Marketplace)
Motherboard: Asus - ROG STRIX Z270i GAMING Mini ITX LGA1151 Motherboard  ($168.44 @ OutletPC)
Total: $405.32
Generated by PCPartPicker 2017-09-24 22:00 EDT-0400
CPU: Intel - Core i7-7700 3.6GHz Quad-Core Processor  ($289.99 @ SuperBiiz)
Motherboard: MSI - B250I GAMING PRO AC Mini ITX LGA1151 Motherboard  ($94.88 @ OutletPC)
Total: $384.87
Generated by PCPartPicker 2017-09-24 22:01 EDT-0400
The locked I7 would be cheaper
im saying the i7 7700k is faster than the i7 7700 on a locked board. But im not sure it its worth the extra money.
Specs:
https://linustechtips.com/topic/838914-mini-itx-first-build/#findComment-10476180
Ahh, my bad
https://linustechtips.com/topic/838914-mini-itx-first-build/#findComment-10476187
Ahh, my bad
All good
Specs:
https://linustechtips.com/topic/838914-mini-itx-first-build/#findComment-10476189
2 minutes ago, pancho2596 said:
So asus b250i, i7 7700, 16gb of ddr4 2400(I tink 32gb is an overkill is that right?), the gpu is ok? and 250ssd and 1tb hhd? is that all I need?
Along with the case and PSU, yeah thats it
https://linustechtips.com/topic/838914-mini-itx-first-build/#findComment-10476198
