About "Load Wattage"
A ryzen 5 1500x will use at most around 70-90w on stock (default) frequencies, 100-120 watts with some simple overclocking (let's say like rising voltage to 1.35v and 3.7..3.8 ghz on all cores), maybe a tiny bit more if you're going overboard overclocking it all the way to 4 Ghz and raise the voltage all the way to 1.42v.
There's basically no Ryzen processor that uses more than 150 watts even when overclocked to the maximum possible.
A RX 580 card will use at most around 230 watts, if you're overclocking it maybe a bit more.
The motherboard will use around 20-30 watts, the memory will use around 2-3 watts per memory stick, hard drives around 6-10w like I said
So even a 550w power supply will be plenty good, even the most demanding game won't make your power supply go over 400 watts or so. Plenty of spare room from 400w to 550w.
Rather than going with a 600w bronze efficiency, you could go with a 520-550w gold efficiency power supply if it costs around the same.
