I have a few 10-12 Switch surge protectors, but I am in search of a 4. I just built my new desk and want to be able to turn off a few things.
when I went desk shopping a while back I found this.
So now I want to add on to my desk. Currently I had some extra switch’s from a car mod project and I have man handled the hell out of a old surge protector. It works, but not as pretty as I was hoping.
ADJ Products PC-4 POWER CENTER https://www.amazon.com/dp/B007EYG04A/ref=cm_sw_r_cp_api_.W7XzbS6MXD1D
this one would work if the outlets were on the back not the top. I might buy it and modify it to my needs.
anyways,
anyone know where I could find a semi small switch surge protecter?
https://linustechtips.com/topic/838677-4switch-surge-protector/
It's not exactly what you are looking for, but the other day I ran into "desktop surge protector" category and thought it was neat:
https://m.newegg.com/products/N82E16812120580
I also just found this which is almost exactly what you are looking for I think:
https://www.bhphotovideo.com/bnh/controller/home?A=details&O=&Q=&ap=y&c3api=1876%2C{creative}%2C{keyword}&gclid=Cj0KCQjwr53OBRCDARIsAL0vKrNcPHeVjbfRkDZCVDvu1fazeWLOU5-XUlC3-xNwHU4tgu0VMibPMvUaAhMsEALw_wcB&is=REG&m=Y&sku=1133810
and this:
https://www.amazon.com/Tripp-Lite-Individually-Controlled-TLP76MSG/dp/B0068LACFI
Hope this helps.
Looking to buy GTX690, other multi-GPU cards, or single-slot graphics cards:
https://linustechtips.com/topic/838677-4switch-surge-protector/#findComment-10473772
and this:
Hope this helps.
That first one is basically what I am looking for, and it might be what I go with.
The second one, I have one that looks just like it, but has 10 outlets, too big to reasonably fit on the desk.
The third one is basically what I am currently using but for my desktop, and other stuff..
I am looking for a small one for just my monitors. So when I dont want to use my 3 side monitors, I can turn them off and just use my 144hr one.(Because Win + P is dumb and buggy af)
Thank you for the reply though, I think that first link is my best bet:]
https://linustechtips.com/topic/838677-4switch-surge-protector/#findComment-10473970
