gpu gtx1060 overclocking problems with oc gtx 1060
Solved by Cyberspirit,
@xtrax Hi do you have your Core Voltage Power Limit and Temp Limit maxed out?
Also could you please send a screenshot of your MSI Afterburner Properties?
Here's some screenshots of my Afterburner:
Ps.: Don't use the Apply overclocking at system startup unless you think you got a stable overclock.
