Stream Phone audio to PC over Bluetooth
Solved by Clown,
I solved my problem with the easiest and most obvious fix there is, installing the drivers. Normally, with a new product, I'll install the drivers almost immediately, the issue I had, though, was that I don't have a CD Player nor could I download the drivers online. So in order to download the drivers, I inserted the disc into my extremely slow laptop. From there I uploaded the folder onto Google Drive and downloaded it from my Desktop. From there it was very straightforward.
