I am getting a new case and I cant find any good one. I have £100 budget and I want a windowed case, it has to be able to have an ATX motherboard, it needs to be able to have at least a 2 fan rad and I dont want it to be mounted externaly like on a CM Storm Scout II. Last thing is I dont want it to be fractal design define R4 or arc midi.
https://linustechtips.com/topic/83800-i-need-case-suggestions/
nzxt phantom series, that is all.
Listen if you care.
https://linustechtips.com/topic/83800-i-need-case-suggestions/#findComment-1140950
Corsair c70
current system:  i5 2500k @4.5ghz cooled by antec 620 - asrock z77 extreme 4 - 8gb corsair RAM - MSI Twin Frorz 7950 in crossfire - XFX 850w  - Fractal design R4 - samsung 840 120gb ssd - 500gb wd blue hdd - 1440p korean qnix monitor (love it!)
https://linustechtips.com/topic/83800-i-need-case-suggestions/#findComment-1140960
Fractal Arc Midi R2. I love mine :3
never mind
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
https://linustechtips.com/topic/83800-i-need-case-suggestions/#findComment-1140962
Slap a tenner on top and you get yourself one hell of a BEAST.
http://www.scan.co.uk/products/silverstone-raven-rv04b-w-black-full-tower-case-usb-30-with-side-window-e-atx-atx-w-o-psu
Seriously, the best layout ever created for any PC, heat is removed so fast it leads in cooling, i own the RVO2-BW, if  you remove the bottom 3 180mm fans, you can mount a 380 rad easily.
Actually this case uses a different orientation o.0 i should check before typing, god i am thick sometimes.
Le Bastardo+
i7 4770k + OCUK Fathom HW labs Black Ice 240 rad + Mayhem's Gigachew orange + 16GB Avexir Core Orange 2133 + Gigachew GA-Z87X-OC + 2x Gigachew WF 780Ti SLi + SoundBlaster Z + 1TB Crucial M550 + 2TB Seagate Barracude 7200rpm + LG BDR/DVDR + Superflower Leadex 1KW Platinum + NZXT Switch 810 Gun Metal + Dell U2713H + Logitech G602 + Ducky DK-9008 Shine 3 MX Brown
Red Alert
FX 8320 AMD = Noctua NHU12P = 8GB Avexir Blitz 2000 = ASUS M5A99X EVO R2.0 = Sapphire Radeon R9 290 TRI-X = 1TB Hitachi Deskstar & 500GB Hitachi Deskstar = Samsung DVDR/CDR = SuperFlower Golden Green HX 550W 80 Plus Gold = Xigmatek Utguard = AOC 22" LED 1920x1080 = Logitech G110 = SteelSeries Sensei RAW
https://linustechtips.com/topic/83800-i-need-case-suggestions/#findComment-1140966
i will see it looks cool but I would prefer cable management grommets.
https://linustechtips.com/topic/83800-i-need-case-suggestions/#findComment-1140999
i hate the looks
Well as you really don't want a R4 or arc R2, maybe the corsair 540
https://linustechtips.com/topic/83800-i-need-case-suggestions/#findComment-1141012
Here is the RVO2, it really is a monster, i will add some pics of my rig, wait a sec, it cooled 2 massively OC'd 480's without a hitch keeping them from rising above 75c O.o
http://www.scan.co.uk/products/silverstone-raven-rv02b-ew-black-full-tower-case-with-side-window-usb-30-3x180mm-quiet-fans-w-o-psu
Here is my old build in it...
Le Bastardo+
Red Alert
https://linustechtips.com/topic/83800-i-need-case-suggestions/#findComment-1141020
i was thinking about it but its £130 but i guess that's my only choice
Well worth it mate, that is all i will say.
Le Bastardo+
Red Alert
https://linustechtips.com/topic/83800-i-need-case-suggestions/#findComment-1141032
the cable management though
https://linustechtips.com/topic/83800-i-need-case-suggestions/#findComment-1141066
Yeah i am not bothered about cable management, i built it for speed at the time, and that is exactly what it did best, was Cray Cray man :P
Le Bastardo+
Red Alert
https://linustechtips.com/topic/83800-i-need-case-suggestions/#findComment-1141072
Listen if you care.
https://linustechtips.com/topic/83800-i-need-case-suggestions/#findComment-1141080
Oops my bad. Here's some that I like in that price range:
1. http://www.newegg.com/Product/Product.aspx?Item=N82E16811146114
2. http://www.newegg.com/Product/Product.aspx?Item=N82E16811139010
3. http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197
Idk you kinda ruled out all the good ones in that price range.
Only victors are allowed to live... this world is merciless like that.
https://linustechtips.com/topic/83800-i-need-case-suggestions/#findComment-1141081
yeh but i read some reviews and apparently its not really strong and i am clean build person
It looks messier than it actually is due to the none braided cables, i never bothered buying cable braiding :P
Also...
http://www.gamersnexus.net/hwreviews/1118-silverstone-rv02b-ew-review
Le Bastardo+
Red Alert
https://linustechtips.com/topic/83800-i-need-case-suggestions/#findComment-1141083
anything fractal is amazing
Intel i7-3770k @ 4.5 GHz                               DCUII GTX 680                            16GB Corsair Vengeance RAM
Sabertooth Z77 ATX                                      WD Caviar Blue 500GB+ 1TB      Corsair Obsidian 750D
Corsair TX850M Watt PSU                            Bad Custom Water Cooling          Samsung 840 Pro SSD
https://linustechtips.com/topic/83800-i-need-case-suggestions/#findComment-1141095
well I like my stuff good quality and good looks. Also dont use any american websites as the prices are a lot different here in england.
https://linustechtips.com/topic/83800-i-need-case-suggestions/#findComment-1141117
