It'll last longer, the phone will learn its new capacity. But many cheap batteries lie about capacity, so I'd suggest getting brand name batteries from a reputable source. Higher capacity batteries are almost always larger in size.
https://linustechtips.com/topic/837767-battery/#findComment-10464535
No damage. Just increased battery life! Just ensure that the battery you purchase is the EXACT same size (as in dimensions)
P.S. 2700 to 3700 is quite the jump. I somehow doubt that the company that sells the 3700mAh battery is telling the truth about their capacity.
"Although there's a problem on the horizon; there's no horizon." - K-2SO
https://linustechtips.com/topic/837767-battery/#findComment-10464539
^ this also... never trust batteries from china too xD bought high capacity ones and they were extremely low when actually used xD
https://linustechtips.com/topic/837767-battery/#findComment-10464544
