i have a i5 4690k at 3.5ghz with a asetek 550lc liquid cooler bought on sale couple years ago i notice that my temperature of my cpu was reaching 80 degrees celsuis while gaming i googled to see if that was bad temps at just stock but all i could see was people with the same i5 overclocked to 4.0ghz-4.4ghz and reaching those temps while gaming with a hyper 212 evo and other coolers. Do i need to a new cpu cooler or more fans in my case and if so i only have a budget of 50 usd.
https://linustechtips.com/topic/837550-is-my-cpu-running-hot/
I would start with a good old cleanup by removing the heatsink of your CPU, reaply thermal paste, clean up dust from rad / filters / fans etc. and see if that improves things.
(also don't trust the internet, there are tons of people who overclock the hell out of everything and actually never did so once...)
https://linustechtips.com/topic/837550-is-my-cpu-running-hot/#findComment-10462056
Ok if i do that and the temps still hit that high what would you suggest?
https://linustechtips.com/topic/837550-is-my-cpu-running-hot/#findComment-10462096
4 minutes ago, Merp83 said:
Buy a new cooler.
Not necessarily, could just be TIM under ihs has degraded.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/837550-is-my-cpu-running-hot/#findComment-10462135
12 minutes ago, Gunner94 said:
o.O what?
Thermal paste only works when it is wet, once it dries it is like trying to cool a cpu with a piece of paper between that and the cooler.
Your cooler probably needs a good cleaning as well.
Also, don't buy a 212 evo, it is bad value.
Intel Xeon 1650 V0 (4.4GHz @1.4V), ASRock X79 Extreme6, 32GB of HyperX 1866, Sapphire Nitro+ 5700XT, Silverstone Redline (black) RL05BB-W, Crucial MX500 500GB SSD, TeamGroup GX2 512GB SSD, WD AV-25 1TB 2.5" HDD with generic Chinese 120GB SSD as cache, x2 Seagate 2TB SSHD(RAID 0) with generic Chinese 240GB SSD as cache, SeaSonic Focus Plus Gold 850, x2 Acer H236HL, Acer V277U be quiet! Dark Rock Pro 4, Logitech K120, Tecknet "Gaming" mouse, Creative Inspire T2900, HyperX Cloud Flight Wireless headset, Windows 10 Pro 64 bit
https://linustechtips.com/topic/837550-is-my-cpu-running-hot/#findComment-10462219
28 minutes ago, Gunner94 said:
o.O what?
Basically, that piece of metal on your cpu? That's just a heatspreader.
The actual part that contains transistors is much, much smaller. When you remove that piece of metal, you get something that looks like this.
pic_disp.php?id=29847&width=400
The metal thing on the right with a bunch of thermal paste is the part that actually has transistors. The thing on the left is the piece of metal you actually see on top of the CPU. It's called the IHS (internal heat spreader)
There's thermal paste between the die (physical part with actual transistors) and the IHS. That thermal paste can degrade over time, which results in worse thermal performance.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/837550-is-my-cpu-running-hot/#findComment-10462262
