Will It Be A Problem?
Go to solution Solved by Recon-UK,
My MSI 790FX-GD70 has a clip missing on the 3rd slot i think, as long as the damage is only the clip and not the actual slot it's self, it is still safe to use, just ensure you screw down the GPU firmly, or use something to support it if it is a heavy card.
Hello Folks!
So I made a small/big mistake with my stupid big hands. :P
Today when I made some modifications to my PC I broke the little clip on the PCI slot.
Will this be a problem?
Pic of what clip I meant. sorry for the big picture. ^^
"Probably Because I'm A Dangerous Sociopath With A Long History Of Violence"
https://linustechtips.com/topic/83700-will-it-be-a-problem/
If you plan to put a card in there, then yes.
Ryzen 9 5950x | NH-D15 | ROG STRIX X570-F | G.Skill 32GB DDR4 | MSI Ventus RTX 3080 | WD Black SN850 1TB PCIe 4 | Samsung 850 EVO + 860 EVO 1TB | Corsair 5000D Airflow
Dell S3422DWG | Dell S2721DGF | Corsair K70 RGB Keyboard | Logitech G502 Lightspeed | ATH-R70x
https://linustechtips.com/topic/83700-will-it-be-a-problem/#findComment-1139685
Le Bastardo+
i7 4770k + OCUK Fathom HW labs Black Ice 240 rad + Mayhem's Gigachew orange + 16GB Avexir Core Orange 2133 + Gigachew GA-Z87X-OC + 2x Gigachew WF 780Ti SLi + SoundBlaster Z + 1TB Crucial M550 + 2TB Seagate Barracude 7200rpm + LG BDR/DVDR + Superflower Leadex 1KW Platinum + NZXT Switch 810 Gun Metal + Dell U2713H + Logitech G602 + Ducky DK-9008 Shine 3 MX Brown
Red Alert
FX 8320 AMD = Noctua NHU12P = 8GB Avexir Blitz 2000 = ASUS M5A99X EVO R2.0 = Sapphire Radeon R9 290 TRI-X = 1TB Hitachi Deskstar & 500GB Hitachi Deskstar = Samsung DVDR/CDR = SuperFlower Golden Green HX 550W 80 Plus Gold = Xigmatek Utguard = AOC 22" LED 1920x1080 = Logitech G110 = SteelSeries Sensei RAW
https://linustechtips.com/topic/83700-will-it-be-a-problem/#findComment-1139686
I plan to yes :o
not if it still locks alright. u may have some diffculties but nothing a human being cant do xD
So, it's only to hold the card in place, nothing essential?
https://linustechtips.com/topic/83700-will-it-be-a-problem/#findComment-1139699
Oh good, thanks. ^^
https://linustechtips.com/topic/83700-will-it-be-a-problem/#findComment-1139704
I plan to yes :o
It's a plastic clip. I don't recall plastic allowing the flow of electricity. So no.
You'll have an Issue with one end of the card possibly not sitting in the slot properly.
https://linustechtips.com/topic/83700-will-it-be-a-problem/#findComment-1139709
Oh good, thanks. ^^
No problem and good luck, do come back if any more problems arise :)
Le Bastardo+
Red Alert
https://linustechtips.com/topic/83700-will-it-be-a-problem/#findComment-1139713
I tried to pout it in, and it looks alright to me, a little sag maybe, but not more then before. Let's hope it works, othewise, will it be ok to use the second PCi slot? @Recon-UK
https://linustechtips.com/topic/83700-will-it-be-a-problem/#findComment-1139715
The second slot is a wired 8x slot, it should be perfectly fine, there will be a very tiny performance impact by using an 8x slot, but nothing you will notice in the real world.
Le Bastardo+
Red Alert
https://linustechtips.com/topic/83700-will-it-be-a-problem/#findComment-1139722
well afaik the 660ti only has a small bandwith anyway, and with Ivy 8x is like 16x right?^^
https://linustechtips.com/topic/83700-will-it-be-a-problem/#findComment-1139729
Ahh yes when taking into consideration the 3RD Gen certification, you will effectively be running PCI-E Gen 2.0 x16 speeds at PCI-E 3.0 x8.
No performance issues what so ever.
Le Bastardo+
Red Alert
https://linustechtips.com/topic/83700-will-it-be-a-problem/#findComment-1139734
awesome, will report back if the 1st slot still works. ^^
https://linustechtips.com/topic/83700-will-it-be-a-problem/#findComment-1139739
Cool :)
Le Bastardo+
Red Alert
https://linustechtips.com/topic/83700-will-it-be-a-problem/#findComment-1139764
Cool :)
Looks like it still works, no sag, no bend, looks good to me. :)
I'm so relieved right now xD Thanks guys. :)
https://linustechtips.com/topic/83700-will-it-be-a-problem/#findComment-1139797
Good stuff, go enjoy it :)
Le Bastardo+
Red Alert
https://linustechtips.com/topic/83700-will-it-be-a-problem/#findComment-1139802
Not at all. I broke the clip off the motherboard I am using currently because it was a nuisance. It is only there to support heavy cards, but it isn't really necessary.
4790k @ 4.5Ghz 1.180v NZXT Kraken X31 | MSI Z97 Krait | Kingston Hyper X Fury 32GB 1866Mhz, 2 DIMMs white and 2 black | GTX 980 Ti - G1 Gaming | GTX 680 - Reference | SilverStone ST75F-P | Phanteks Enthoo Pro
https://linustechtips.com/topic/83700-will-it-be-a-problem/#findComment-1139818
