Dark Base Pro's LED strips
Go to solution Solved by reniat,
3 hours ago, HeLiOn PrImE said:
Interesting. I did ask the guys from BeQuiet using the comment section of their presentation video.
They immediately said it's possible, but I still had my doubts, because I figured that maybe those don't work like standard RGB strips.
Leaving the connector aside, do the strips have the same LEDs for all colors, or does each color come from a separate LED?
(and don't worry, your nails are fine).
all the LEDs can be any of the given colors, and the set will be the same color. If you have both strips connected they will also be the same color (since it's all being controlled from the same controller).
If anyone of you owns a Dark Base Pro 900, I'd appreciate some info on it's two LED strips?
From what I've seen in the tons of reviews, when connected to the controller, they can switch between 5 colors and the off state.
Can they actually be connected to the motherboard or a separate controller to produce different colors or color combinations?
https://linustechtips.com/topic/836213-dark-base-pros-led-strips/
I'm not sure what kind of connector is it, but it's definitely not the current standard for RGB strips. It won't fit things like asus AURA and the like. Here's a picture in case you or someone else can identify it: (ignore my dirty nails. I was working on my bike today)
Gaming build:
CPU: i7-7700k (5.0ghz, 1.312v)
GPU(s): Asus Strix 1080ti OC (~2063mhz)
Memory: 32GB (4x8) DDR4 G.Skill TridentZ RGB 3000mhz
Motherboard: Asus Prime z270-AR
PSU: Seasonic Prime Titanium 850W
Cooler: Custom water loop (420mm rad + 360mm rad)
Case: Be quiet! Dark base pro 900 (silver)
Primary storage: Samsung 960 evo m.2 SSD (500gb)
Secondary storage: Samsung 850 evo SSD (250gb)
Server build:
OS: Ubuntu server 16.04 LTS (though will probably upgrade to 17.04 for better ryzen support)
CPU: Ryzen R7 1700x
Memory: Ballistix Sport LT 16GB
Motherboard: Asrock B350 m4 pro
PSU: Corsair CX550M
Cooler: Cooler master hyper 212 evo
Storage: 2TB WD Red x1, 128gb OCZ SSD for OS
Case: HAF 932 adv
Gaming build:
Server build:
CPU: Ryzen R7 1700x
PSU: Corsair CX550M
Case: HAF 932 adv
