 I pulled an old 1tb disk out of my old laptop and I have already taken all of the important stuff off of it. I got to the windows disk management page but I don't have the option to reformat the disk. Also, there are other partitions besides the primary that I don't need anymore because it is no longer an os drive but they can't seem to be worked with at all. 59bebd76b77d6_2017-09-1712_15_41-ComputerManagement.png.15d5ab838f1aef0b789c692e9a7c2f44.png
The Disk 1 is the one imm trying to wipe.
https://linustechtips.com/topic/836032-reformatting-old-os-drive/
So?
I don't see any text
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
Run CMD as Admin
Diskpart
Select Disk 1
Clean
Exit
Then format as normal
Main Rig:-
Server:-
2 minutes ago, Kd4lif3 said:
59bec8af3ae2e_2017-09-1713_10_16-Administrator_C__WINDOWS_system32_cmd.exe-Diskpart.png.fada69e9485f9baf4ba43cf43e3b79b2.png
Did you boot from the drive you're trying to format? If so reboot and boot from your other drive before following these steps.
MAKE SURE YOU CHECK THE DRIVE IS STILL DISK 1 BEFORE YOU FORMAT IT!!!!!!!!!!!!!!!
Main Rig:-
Server:-
no, I did not boot from it and yes it is still disk 1
You did, according to the screenshot Disk 1 is currently the boot drive and contains the Windows partition that's in use.
Reboot, boot from your 120GB then try to format again.
Main Rig:-
Server:-
that's strange. I have already deleted a bunch of windows stuff off of it that would have normally been running had I been booted on that drive. I restarted regardless and I still have the same issue. i made sure my adata SSD was at the top of boot order and no luck.
imm confused. Is there a chance that a background program is running off of that drive and screwing things over
It's possible that Windows is using the page file from your second drive but other than that I'm not sure.
The guaranteed method is get a boot CD or Linux Live disc and do the format outside of Windows.
Main Rig:-
Server:-
Ya, I don't think I can do either of those rn. Is there anything else I can try. And also, how can you tell what device I am booted into from the screenshot.
Disable Windows pagefile and try again....
http://www.tomshardware.co.uk/ssd-performance-tweak,review-32203-4.html
If you look at the first screenshot it tells you that Drive D on Disk 1 is being used to store a pagefile (It says Pagefile below the partition). Your boot drive is shown as Drive C on Disk 0 (It says Boot below the partition).
Main Rig:-
Server:-
