So I'm running a stock cooler on a Ryzen 7 1700 @3.75 GHz and I'm idling at anywhere from 52-54 degrees celsius and my peak temperature on ryzen master when I'm under full load is around 84 degrees even though under aida64 indicates me being at 77-79 degrees. So is my CPU running too hot and do I need to drop the clockspeed a little bit?
https://linustechtips.com/topic/835706-is-my-cpu-temperature-fine/
how about dropping the voltage? can that go down?
Desktop benching:
10 minutes ago, CardinalHunter said:
I doubt I can drop the voltage cuz it's running on 1.1875V and I ran about 6 hours of aida64 with it and it was stable so do I pass?
then stability is fine. How high is the ambient temps? 3.8Ghz at 1.35V is reported to be around 75C with stock cooler in full load.
Desktop benching:
So did I do my overclock right sorry this is my first time overclocking also how have I been able to achieve a stable 3.75Ghz with only 1.1875V when it takes someone else's cpu to 1.35V to get to 3.8GHZ
You are just lucky to get a good chip.
Why 2133MHz RAM? Havent overclocked RAM yet?
Desktop benching:
5 hours ago, CardinalHunter said:
wait so how do I overclock my ram I'm not sure I know a lot about it care to enlighten me on this subject?
There should be an option to enable XMP profile.
Desktop benching:
