3 minutes ago, SamuraiAlex said:
Yes I formatted the disk in the windows setup
Will it let you reformat? There should the option to select MBR when you do.
I would rather agree on what we share, than fight on what we don't. - Myself
FULL PC SPECS ON PROFILE https://linustechtips.com/main/profile/454099-thinkfreely/
https://linustechtips.com/topic/834458-help/#findComment-10429596
So if you have a USB download a bootable drive. Then load up the BIOS, it should show the drive in boot options. Change it to the SSD and you should see 1-2 partitions. Delete each partition, then re-run the installer and it should allow you to install directly onto the ssd. If not, then you need to connect it to another computer, go into disk management, and on the ssd do a clean format to CSM, or if available just hit "convert" to CSM
https://linustechtips.com/topic/834458-help/#findComment-10429742
Cheers mate got it working now.
thanks for the help:D
https://linustechtips.com/topic/834458-help/#findComment-10429757
