When you load the install media it should ask you which drive you want to install to. Just make sure you have the SSD selected. Use the size of the drive as an indicator if it doesn't tell you the name.
i7-4790k | MSI Z97 GAMING-5 | Corsair Vengeance 16 GB | Samsung EVO-850 250GB SSD & WD blue 1 TB HDD | EVGA 1070 SC | Red NZXT H440 | Cooler Master G650W
https://linustechtips.com/topic/834333-help-needed/#findComment-10428364
