Hello guys. Today I got a great deal on a 4GB DDR3 1600mhz RAM and a Corsair VS450 for £15, although not everything is good news. When I was cleaning the fan on the PSU, I broke one if its blades. What can I do about this? I can replace the fan with one of my 3-pin case fans, but will there be any difference in noise/performance? I could superglue it back on, but that's just too janky, even for me.
Many thanks, Bruno.
Quote me so I can reply back :)
MY PC-> PSU: EVGA SuperNOVA T2 1000W 80 Plus Titanium MOTHERBOARD: ASUS X370 Crosshair VI Hero CPU: RYZEN 7 3700X RAM: G.Skill 32GB (4X8GB) DDR4 3200MHz C14 GPU: EVGA GTX 1080Ti FTW3 HYBRID STORAGE: Samsung 970 EVO 500GB NVMe SSD; 2TB WD Caviar Blue; Crucial MX500 500GB SSD CUSTOM LOOP: EK-Velocity Nickel + Plexi CPU block, EK-FC1080 GTX Ti Acetal + Nickel GPU Block w/ EK-FC1080 GTX Ti Backplate, EK-XRES 140 Revo D5 PWM, EK-CoolStream PE 240 w/ 2x Noctua NF-F12 Chromax fans, EK-ACF Fitting 10/13mm Nickel, Mayhems UV White tubing 13/10mm, 3x Noctua NF-S12A Chromax case fans
https://linustechtips.com/topic/833231-help/
Many thanks, Bruno.
I would just replace the fan if possible for a fan of the same size. Make sure you know what connection for a fan the PSU takes, as it may be using a 2 pin header like this one: Image result for 2 pin psu fan header
You can buy pretty much any type of fan with any type of connector for like £3 which will just run at a low RPM so just remember to make sure what connector for fans the PSU uses and you're set :D
If you open up the PSU carefully and avoid touching any components other than the fan inside then you should just be able to screw in a new fan.
10 minutes ago, hconverse02 said:
Nothing is wrong with superglue though
^ Don't do that. That is a dumb idea (No offence :3).
I once did the unthinkable, back many headphones ago...
I split an audio split, again
https://linustechtips.com/topic/833231-help/#findComment-10416051
Many thanks, Bruno.
super glue it on, but in this case more is better, u dont want no blade flying around the PSU mid use
subscribe to pewdiepie
https://linustechtips.com/topic/833231-help/#findComment-10416057
I replaced it with a case fan I had and connected the 3-pin connecter to a fan header on my motherboard. Although, this is only a temporary solution, I'll buy a new fan once I find one of the same model at a good price online. Thank you for replying.
https://linustechtips.com/topic/833231-help/#findComment-10416335
Again, don't do this please. The blade will never be correctly balanced if you are adding the weight of super glue to a blade, or will the blade be in line with the other blades and could even hurt performance because of it not being precisely alligned.
Not the smartest idea as a brand new fan to replace the current will probably be cheaper than any good super glue...
https://linustechtips.com/topic/833231-help/#findComment-10421235
