I have an old Inspiron 560 motherboard with a BIOS that limits my chip to no overclocking. Id like to flash a custom BIOS onto my mobo to give it overclocking abilities. Ive tried a few methods, but cant seem to figure it out. Any suggestions? Its an American Megatrends BIOS
https://linustechtips.com/topic/832629-need-to-crack-a-cpu/
Its EXTREMELY unlikely, there are several limitations that would prevent you from overclocking such as chipset, power supply, and CPU cooler. If your chipset doesnt support overclocking then you arent overclocking, the other two can be dealt with easily. And you most likely will not be able to install a custom BIOS because most OEM parts are rigged to where if a custom BIOS was installed, something may go wrong. Not all do this but keep that in mind. Since it is Dell I doubt it but still keep if in mind
Main system "Kethlon":
Core i7 3820 - Intel Desktop Board DX79TO - 32GB 1600MHz DDR3 RAM Dual channel - EVGA GTX 1050 Ti SSC - EVGA 550 B3 - PNY 120GB SSD (boot),WD Blue 1TB (Mass Storage)
See profile for full specs
Primary Laptop "Vengeance":
HP HDX16 1370US - Intel Core2Duo P8700 - 4GB DDR2 800MHz RAM Samsung - HGST 1TB 7200RPM (Windows 7, Linux, MacOS 10.11.6) - Nvidia GT 130M 1GB DDR2
Downed Laptop "Xarasky":
MacBookPro3,1 - Core2Duo T7700 - 4GB DDR2 RAM 667MHz - Nvidia 8600M GT 256MB VRAM - 640GB HDD (MacOS and Windows)
Testing laptop #1 "Leonard":
HP 15 F387WM - AMD A8 7410 APU - 8GB DDR3 Samsung RAM 1600MHz - AMD Radeon R5 graphics (1GB VRAM partitioned out of physical RAM) - 500GB WD Blue mobile drive
https://linustechtips.com/topic/832629-need-to-crack-a-cpu/#findComment-10410603
but how should i go about this
https://linustechtips.com/topic/832629-need-to-crack-a-cpu/#findComment-10410607
Its just too much work and far too much risk, I would recommend just saving up for something newer
https://linustechtips.com/topic/832629-need-to-crack-a-cpu/#findComment-10410611
its a side PC that i have as a project, so if you know how to do it, id appreciate the advice.
Well I would first do research on the chipsets on the board and see if they have any native overclocking ability at all, if not then you simply are not overclocking.
https://linustechtips.com/topic/832629-need-to-crack-a-cpu/#findComment-10410619
