Including Cable?
Go to solution Solved by iRileyx,
If the 27inch variant does then the 24 most likely will.
Even my cheap £100 Asus monitors came with a hdmi and display port cable, I think its pretty standard for them to be included
The G24c can anyone help me search on whether it comes with a Displayport cable i cant find information anywhere, the G27c on amazon says that it comes with and HDMI and a Displayport, but thats a different monitor
I've looked on newegg and amazon, thank you for the help
https://linustechtips.com/topic/832557-including-cable/
It comes with both an HDMI, and a DP cable.
Best Excuses:
        #1(simple) "Well, I never liked that stupid thing anyway!"
        #2(complex) "Obviously there was a flaw in the material, probably due to the inadvertent introduction of contaminants during the manufacturing process."
https://linustechtips.com/topic/832557-including-cable/#findComment-10409839
