@Introoke you would want the Dual 6+2 extension kit so that you have proper connectivity for your GPU. The dual 6+2 is two 6+2 PCI-E connections which can be either 8 pin PCI-E or 6-pin PCI-E depending on your needs, provides better future compatibility too for GPU upgrades you may or may not do.
