Budget? What will you pair it with?
Desktop benching:
https://linustechtips.com/topic/831943-help-me-pick-cpu/#findComment-10403309
3 hours ago, Anas Dweik said:
Hi guy
is there a better or same preference  cpu then i7 7700k with same price or lower ?? ryzen cpus ?
What about a Ryzen 5 1600 and upgrade your graphics card? The 1600 won't bottleneck any of the current gpu s, unless you get the Pascal monster.
  • CPU
    Ryzen 5 1600 OC 3,7ghz
  • Motherboard
    ASrock AB350 Pro4 ATX
  • RAM
    A-Data 2666mhz upgraded to Corsair LPX 2x8gb 3000mhz
  • GPU
    GTX 1060 6gb
  • Case
    Segotep Chariot TF
  • Storage
    1TB HDD, 240gb M.2 Intel NVMe SSD
  • PSU
    Evga 600w B+
  • Display(s)
    Samsung Full HD 24' Free sync
  • Cooling
    3x 120mm case fans
  • Keyboard
    Razer BlackWidow Chroma V2
  • Mouse
    Razer DeathAdder Elite
  • Sound
    Razer Kraken Pro
  • Operating System
    Windows 10 Pro
https://linustechtips.com/topic/831943-help-me-pick-cpu/#findComment-10403665
