[Question] [NOT SAME POST] Connecting 1 monitor to both onboard and gpu
Cinyk
Alright, I got kind of a weird one, I use dual monitors, my right one is always connected to my GPU but I connect my left one (better monitor) to my onboard and to my dedicated card(2 different cables, 1 is HDMI, the other DVI-D), depending if I'm bitcoin mining or not (So I can still play light games on my igpu when I'm mining) .
Does anyone know of a way to always have my left monitor connected to both my Onboard & Dedicated and choose which one I want to use on the fly without having to unplug the other cable every time ? (Maybe a program or something?)
Thanks!
Just now, Pample said:
Just use the monitors input selection function.
holy fuck I'm retarded ._.
Doing that makes windows think that the monitor is in fact two monitors (I end up with 3 virtual screens instead of 2). Is there a way to disable either the hdmi one or the dvi one and re-enable either on the fly through a program or something so I don't have to actually unplug one of the two cables every time I want to switch from my onboard graphics to dedicated ones?
Thanks
Edited by SansVarnic
Fixed Formatting
Does Windows recognize the one monitor as both? If it does, you can mirror them together.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
-Merged Threads-
The second question is more or less a continuation of the first.
Reputation is a Lifetime to create but seconds to destroy.
 CHRISTIAN MEMBER
I mirrored them but it doesn't really solve my problem, it just uses my gpu for every game/task whether I'm on hdmi or dvi (on the monitor). But if I actually unplug either of the cables from my pc it launches the game/task accordingly (using the gpu/igpu whichever is left connected)
I just want an easy way to switch between each without having to unplug because the back of my case isn't super accessible. (Also while I mine my gets pretty laggy doing basic things unless I run on iGPU)
What about using a splitter? You can toggle the input/output you need with a click or flip of a switch. Just look up "KVM switches".
The thing is the monitor is a 144hz monitor, stuck at 60 on HDMI, and 144 on DVI-D, wouldn't I lose the 144Hz capability with one of those? I honestly can't find much
Because I do use DVI (144HZ) often when I'm not mining
The thing is the monitor is a 144hz monitor, stuck at 60 on HDMI, and 144 on DVI, wouldn't I lose the 144Hz capability with one of those? I honestly can't find much
That might depend on the KVM, but most are pass-throughs that don't affect the monitor.
Would you mind linking me an example ? I can't find any with both DVI and HDMI on both ends
