Really strange USB issue with my system.
First some background. Currently, I have the build shown in my description (https://pcpartpicker.com/b/xjf8TW). With the following USB devices connected: Corsair K95 (not the new one), Logitech G502 (Mouse), A Polaris RGB mousepad (sorry, got it on sale for pretty cheap) Logitech G930 (Headset). Currently, I have the keyboard connected to the USB hub built into my monitor. I also have 4 PS Move cameras connected via usb. Everything is connected to the ports in the back of the mobo (nothing connected to the front ports).
Here's the problem. While in game, my USB devices will randomly disconnect. I have been unable to figure out anything that correlates with them disconnecting, it seems totally random. It's also interesting that my mouse doesn't disconnect ever but everything else does. It will wait a few seconds and then everything reconnects at the same time and I get a notification: "The last device that you plugged in was not recognized." When I go look in device manager, everything looks totally normal. This also only seems to happen while gaming, when browsing the web, I have never had this happen. Also, once everything disconnects, whatever the last input from the keyboard continues to be sent. For example, if I was holding "W" when it disconnected in a FPS, I would continue walking forward until it reconnects.
Because this seems to only happen during gaming, my best guess is an issue with bandwidth. I've also read online that this could be a broken mobo but not sure if I believe that (source: https://forums.techguy.org/threads/windows-10-all-usb-devices-disconnect-randomly.1189627/). #denvercoder9.
Also attached a screenshot of my device manager + settings devices. Please let me know if there is any more information that would be helpful to diagnose this issue. Thanks!
EDIT: Forgot to include some unique things about my build: Using 2 16GB dims for ram (see build, they were out of the one I wanted and I really wanted my pc). Also copied all of my data (boot drive) from a sata ssd to my M.2 ssd when I got it. From what I've heard, this can cause weird problems but this issue seems pretty unrelated.
Main PC - Windows 10 (https://pcpartpicker.com/b/xjf8TW)
CPU: i7 6800k @4.2GHz (Kraken x61)
Mobo: ASUS x99 Gaming
GPU: ASUS GTX 1080 STRIX
RAM: 32GB DDR4 Ram
Storage: Intel 600p NVMe PCIe SSD (512GB), 2TB WD Green, 500GB WD Blue
Case: Phanteks Enthoo Evolv ATX
PSU: EVGA 850W 80+ Gold Modular PSU
Display: ASUS PH278Q (1440p 144hz gsync)
Keyboard: Corsair K95 RGB (MX Brown)
Mouse: Logitech G502 Spectrum
Audio: Logitech G930 Headset, Logitech Z506 5.1 Speakers
Server - Ubuntu
CPU: i5 3470 @3.2GHz (Stock)
RAM: 16GB DDR3 Ram
Storage: 2TB WD Green
Gaming Laptop - ASUS ROG G751JT-WH71(WX) - Windows 10
CPU: i7 4720HQ @2.6GHz
GPU: GTX 970M (3GB)
RAM: 16GB DDR3
Storage: 500GB Samsung 850 Evo, 1TB Toshiba HDD
Display: 17.3" display (1080p 75hz gsync)
Work Laptop - Razer Blade Stealth - Debian + KDE
CPU: i7 7500U @2.7GHz / 3.5GHz (Base/Turbo)
RAM: 16GB
Storage: 512GB M.2 SSD
Display: 13.3" QHD+ 3200x1800 touchscreen (16:9)
https://linustechtips.com/topic/831727-really-strange-usb-issue-with-my-system/
5 minutes ago, Thermosman said:
Have you determined any USB ports that always work?
From what I can tell, it seems that no ports work reliably. I have all of my cables tied together so it's really hard to find which one goes to the mouse. I've tried changing them up quite a bit with no success.
RAM: 32GB DDR4 Ram
Server - Ubuntu
RAM: 16GB DDR3 Ram
GPU: GTX 970M (3GB)
RAM: 16GB DDR3
RAM: 16GB
Try disconnecting the cameras, also when usb ports stop working does the power on them shut off also?
CPU: Ryzen 1700@3.9ghz; GPU: EVGA 560 Ti 1gb; RAM: 16gb 2x8 Corsair Vengeance LPX DDR4-3000; PCPP: https://pcpartpicker.com/list/b3xzzM
Yeah when it disconnects, the LEDs go off on all devices (except the mouse).
RAM: 32GB DDR4 Ram
Server - Ubuntu
RAM: 16GB DDR3 Ram
GPU: GTX 970M (3GB)
RAM: 16GB DDR3
RAM: 16GB
 Update:Just got the same issue with all cameras unplugged.
Also had the problem like 7 times when not playing a game so it seems unrelated to amount of input and may not be bandwidth related. I also forgot to mention that I have checked every single power saving option and turned it off. Ports will never turn off (in theory).
RAM: 32GB DDR4 Ram
Server - Ubuntu
RAM: 16GB DDR3 Ram
GPU: GTX 970M (3GB)
RAM: 16GB DDR3
RAM: 16GB
Update: I've been able to get the settings app (devices tab) open when everything disconnects and it briefly flashes driver error on all of the devices and then the entire settings app crashes. It's happened at least 20 times today, I shit you not. I'm just about ready to throw my pc out the window. This single reply has been such a struggle to type out, it's disconnected 3 times already and I'm not even done writi
RAM: 32GB DDR4 Ram
Server - Ubuntu
RAM: 16GB DDR3 Ram
GPU: GTX 970M (3GB)
RAM: 16GB DDR3
RAM: 16GB
  • 3 weeks later...
Update on this: After quite a bit of trial and error, I have narrowed the issue down to my Corsair devices. I have contacted Corsair support and will post once I find a solution.
RAM: 32GB DDR4 Ram
Server - Ubuntu
RAM: 16GB DDR3 Ram
GPU: GTX 970M (3GB)
RAM: 16GB DDR3
RAM: 16GB
