Monitor NOT working!
TurkarYash
So I have 2 monitors  , one running via a HDMI to DVI-D converter (Converter on the monitor side - HDMI coming from graphics card and DVI-D on the motherboard side) and another (Problem with this one) running via a VGA to HDMI converter (On the motherboard side ) , Since I upgraded my RAM this monitor flickers and turns off or even freezes.
Is it related to the RAM upgrade? I checked the converters independently and they seem to be working fine , I switched the ports on the graphics card and they seem to be working fine as well.
well, take out the extra RAM, and see if the problem disappears.
if (problemDissapears):
  RamIsTheIssue = True
else:
  RamIsTheIssue = False
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Desktop:
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 - Lots of RGB lights I never change
Laptop:
HP Spectre X360 - i7 8560U - MX150 - 2TB SSD - 16GB DDR4
else:
While adding the RAM I had removed my old stick to clean the PC and then added the RAM , now I dont know which stick is new and which is the old one
else:
So i checked with both sticks independently and the RAM doesn't seem to be the problem
