I've been looking to build a new pc for a very long time and am definitely set on buying one very soon. My main focus is purely gaming, I have no interest in changing the CPU to AMD. Here is my build so far, https://pcpartpicker.com/list/VFjfWX
I have mostly everything picked out besides the case and monitor and possibly some other small accessories. My budget is around 2300 but i'd really like to stay under if possible. I am pretty much set on a 144hz 1440p 27 inch monitor but not sure which one I should go with so if anyone has some suggestions please let me know. I was looking at the BenQ but wasn't sure if I could save a few bucks and go with something else. Also the case, I am not set on one what so ever and would very much appreciate any suggestions. I'd like to keep the case under the 120$ mark if possible. Thanks to everyone who helps out :)
https://linustechtips.com/topic/831065-first-build/
Little over, added a nice 1.1tb ssd. :P
Great case and under the price for the case.
https://pcpartpicker.com/list/FWNRd6
https://linustechtips.com/topic/831065-first-build/#findComment-10394178
i would get this monitor.  https://www.acer.com/ac/en/US/content/model/UM.HG0AA.001  unless you want g-sync.  i have this monitor and it is great.  there is a ips version for i beleve like another 50 bucks but i didnt really see the difference between them when i saw them and as for the case thats really up to you,  like if you have a particular color theme your going for or something like that but if you just want suggestions then the s340 from nzxt is really nice case and is really popular especally for its price
Current Rig=  AMD Ryzen 9 5900x, Asus Crosshair Hero VIII, EVGA RTX 3070 FTW3 ultra, 32gb Corsair Vengence Pro RGB 3000hz White, EVGA 750 P2 PSU, 1TB Samsung 980 Pro, 500gb samsung 860 evo, 250GB Samsung 850 evo, 2TB Samsung 970 Evo Plus, 2TB seagate firecuda sshd,  LianLi PC 011 Dynamic XL ROG edition, Corsair h150i elite capelix
https://linustechtips.com/topic/831065-first-build/#findComment-10394184
Oh man, I saw that one a little bit ago but oh my is it ugly. I was super excited because it had everything I wanted and it was cheaper but then I saw the picture lol
https://linustechtips.com/topic/831065-first-build/#findComment-10394186
hey it may be ugly but its a dam solid monitor for the price.  i personally dont care about ascetics when it comes to my monitors.  as long as it has the features that im looking for at a good price then im happy
https://linustechtips.com/topic/831065-first-build/#findComment-10394195
https://pcpartpicker.com/product/mNBrxr/aoc-ag271qx-270-2560x1440-144hz-monitor-ag271qx
Hmm?
https://linustechtips.com/topic/831065-first-build/#findComment-10394202
do you need an itx pc? or just a regular one will do?
https://linustechtips.com/topic/831065-first-build/#findComment-10394212
Anything honestly
CPU: Intel - Core i7-6700K 4.0GHz Quad-Core Processor  ($309.99 @ SuperBiiz)
CPU Cooler: Reeven - Justice 82.1 CFM Sleeve Bearing CPU Cooler  ($41.49 @ Newegg Marketplace) on par with the H110i in performance.
Motherboard: ASRock - Z270 Killer SLI/ac ATX LGA1151 Motherboard  ($100.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  ($129.99 @ Newegg)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive  ($89.99 @ B&H)
Storage: Toshiba - P300 2TB 3.5" 7200RPM Internal Hard Drive  ($61.97 @ Amazon)
Video Card: Gigabyte - GeForce GTX 1080 Ti 11GB AORUS Video Card  ($739.98 @ SuperBiiz)
Case: Fractal Design - Meshify C ATX Mid Tower Case  ($89.99 @ SuperBiiz)
Power Supply: Corsair - TXM Gold 850W 80+ Gold Certified Semi-Modular ATX Power Supply  ($99.99 @ Amazon)
Monitor: AOC - AG271QG 27.0" 2560x1440 165Hz Monitor  ($625.99 @ B&H)
Total: $2290.36
Generated by PCPartPicker 2017-09-05 00:15 EDT-0400
https://linustechtips.com/topic/831065-first-build/#findComment-10394230
Total: $2290.36
Why the change of the processor and PSU? Also, I'd be going with a cheaper monitor. Do not need 165 Hz
https://linustechtips.com/topic/831065-first-build/#findComment-10394235
Total: $2290.36
https://pcpartpicker.com/list/LBsz3F Thoughts? May go back to my original motherboard and possibly change RAM if needed.
https://linustechtips.com/topic/831065-first-build/#findComment-10394256
I'd stick with the cheaper asrock board and for $50 you can get a g-sync 1440p 144hz monitor. PSU is much worse than the TX and the H7 is a downgrade from the justice.
https://linustechtips.com/topic/831065-first-build/#findComment-10394319
The reason I changed cooler was because of how ugly it was, I was also trying to save a bit of money in some areas. Regarding the PSU, 850W is not necessary what so ever.
https://linustechtips.com/topic/831065-first-build/#findComment-10394343
i left the 850w PSU in there for SLI headroom, just find a 550w evga g2/3, seasonic focus plus, bitfenix whisper or corsair TXM/RMx. just replace the fan with another one if you don't like the look. and if you're trying to save money why are you getting a much more expensive mobo?
https://linustechtips.com/topic/831065-first-build/#findComment-10394353
https://pcpartpicker.com/list/MsH6wV
definitlet won't be going into SLI what so ever. How does this look?
https://linustechtips.com/topic/831065-first-build/#findComment-10394369
spend abit more for a TXM 650w. you can get a cheaper aorus 1080ti to save money. otherwise its fine.
https://linustechtips.com/topic/831065-first-build/#findComment-10394392
