Higher Resolution Screen Replacement.
Go to solution Solved by iamdarkyoshi,
Just now, FuckinBuckin said:
Well my CPU Is 5th Gen, is there a way I can find out without opening up my laptop? I'm willing to, but if there is an easier way.
@iamdarkyoshi
I can almost guarantee that it uses a 30 pin connector. Doing a quick google search for the model, the first image of the LCD I found has a 30 pin connector on it.
I'd suggest looking on http://www.panelook.com/ for models with the same size LCD and same interface as yours, and you can sort by screen type. See if you can find an IPS display!
I recently bought an older laptop, the 14" Dell Latitude E5450. I was wondering if it is possible for me to replace 1366x768 screen with a 1080p screen?
Asrock B450m/ac| Ryzen 5 3600x | EVGA GTX 1070 SC ACX3.0| 16 GB DDR4 3200 | Antec 550w SemiModular| 1 TB WD Black | 1TB SP NVME m.2 | 1TB WD BLUE SSD
https://linustechtips.com/topic/831058-higher-resolution-screen-replacement/
According to this site, there are 1080p screens you can get. Just make sure it's compatible before you buy.
https://www.parts-people.com/index.php?action=category&id=140&subid=533&refine=lcd+screen
Desktop: KiRaShi-Intel-2022 (i5-12600K, 5060 Ti) Mobile: Moto Razr 50 Ultra (Razr+ 2024) | 30GB CAN+US+MEX $30/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
From what I see, that uses an Intel iGPU. The ones I've seen with 1080p screens use an nvidia discreet GPU.
I don't have any evidence that it won't work, nor do I that it would. I do know that Dell (and other manufacturers) tend to arbitrarily lock out components from working. Esp. on their business line of laptops. I remember having to flash a custom BIOS on a latitude just to use a Wireless AC wifi card.  So YMMV.
If it uses a 40 pin (LVDS) connector, the max you can do on that cable is 1366x768, unless its a Dual Channel cable, then you can do 1080p.
If its a 30 pin (eDP) connector, you can put a 1080p display in it without issues, and if its a dual channel eDP cable, you can do 4K.
Laptops before 4th gen were almost always LVDS, 4th gen and onwards are almost always eDP.
@iamdarkyoshi
@iamdarkyoshi
