little help ((
i'm running out of ideas what might cause this,
so i just bought new headphones with micro now when i check it from the task bar and try to talk it's running fine, when i test in steam or discord nothing works my friends can't hear my voice,
(i'm using the front plugs)
https://linustechtips.com/topic/830863-little-help/
what do you mean "micro"? Is mic set as default device, can you record audio with like audacity? If able, try using motherboard input instead of front header. Or try it on another laptop
Specs: Amd 1700x | NH-u12s | Asus crosshair hero vi | 2x8g Gskill flare x | Zotac 1080 | Samsung 960 EVO | Seasonic ssr-750GD | Thermaltake core x5 |
https://linustechtips.com/topic/830863-little-help/#findComment-10393924
