Hi,
So I just built my new system and its running fine temp wise (Realan E-D5S case) but I am just looking for peace of mind to improve my air flow a little.
What 120mm case fans would you guys recommend? I know its pretty difficult to go too far wrong here but if people already have them installed and have had a fine time with them that would remove some of my doubt.
Primarily I am looking for quiet, not fussed about looks or neons or anything of that sort. I am one of those boring people who always builds an ugly system as practically as I can :).
I have been looking at the non LED corsair ML120s if anyone has any opinions on them?
http://www.minicase.net/product_E-D5S.html
https://linustechtips.com/topic/830673-case-fan/
3 minutes ago, puppy-kitty said:
Hi,
try noctua.. one of the best fan/cooler manufacturer out there..
Have you tried to perform a sudden temporary interrupt of the electricity flow to your computational device followed by a re-initialization procedure of the central processing unit and associated components?
Personal Rig Specs
CPU: Intel Core i7-7700K @ 4.8GHZ
Motherboard: Asus ROG STRIX Z270H GAMING
Graphics Card: Inno3D ICHILL GEFORCE GTX 1080 TI X3 ULTRA
RAM: Corsair Vengeance LPX Black DDR4 2x8GB @ 3GHZ
Storage: 2 x Samsung NVMe SSD 960 EVO 256GB in Raid | 2 x Seagate 4TB Expansion Desktop
(seagates are originally external drives removed from casing and installed internally)
PSU: Seasonic Prime Titanium 850W
Case: Mission SG GGX 3.5 (same as Rosewill Cullinan or Anidees AI Crystal with other stock fans)
Cooling: Kraken X62 for CPU, Corsair H55 with NZXT Kraken G12 for GPU
https://linustechtips.com/topic/830673-case-fan/#findComment-10390312
I will suggest be Quiet! fans , they have nice 120mm , even the cheapest model does good job , they are quiet and will give you the airflow you want, plus they look slick with their black simple design.
http://www.bequiet.com/en/casefans
https://linustechtips.com/topic/830673-case-fan/#findComment-10390361
