Full specs?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/829791-fresh-build-wont-boot/#findComment-10381881
check if you've plugged the power cord in firmly and if the PSU switch is turned on. also check if you installed the power switch correctly.
https://linustechtips.com/topic/829791-fresh-build-wont-boot/#findComment-10381955
Check all your connections with your power supply specifically the 24 pin atx power.  Check to also to see if it's your outlet, your psu cable to your psu, then check the switch on the back on the psu (unless you don't have one).  If none of this works, disconnect all of your psu cables and reconnect them.  If this still doesn't work, try to see if you messed up your connections with the buttons on your case.  If still it doesn't work then it's probably a problem with your PSU.
https://linustechtips.com/topic/829791-fresh-build-wont-boot/#findComment-10381989
You can test your power supply by shorting the green wire with one of the adjacent black wires with a paper clip. The fan in the power supply should turn on when you switch it on
CPU: Ryzen 1700@3.9ghz; GPU: EVGA 560 Ti 1gb; RAM: 16gb 2x8 Corsair Vengeance LPX DDR4-3000; PCPP: https://pcpartpicker.com/list/b3xzzM
https://linustechtips.com/topic/829791-fresh-build-wont-boot/#findComment-10382076
Make sure front panel headers are plugged in and PSU is turned on and plugged in.
"You don't need headphones, all you need is willpower!" ~MicroCenter employee
How to use a WiiMote and Nunchuck as your mouse!
Specs:
Graphics Card: EVGA 750 Ti SC
PSU: Corsair CS450M
RAM: A-Data XPG V1.0 (1x8GB) (Red)
Procrastinator: Intel i5 4690k @ 4.4GHz 1.3V
Case: NZXT Source 210 Elite (Black)
Speakers and Headphones: Monitor Speakers and Phlips SHP9500s
MoBo: MSI Z97 PC MATE
SSD: SanDisk Ultra II (240GB)
Monitor: LG 29UM68-P
Mouse: Mionix Naos 7000
Keyboard: Corsair K70 RGB (2016) (Browns)
Webcam/mic: Logitech C270
https://linustechtips.com/topic/829791-fresh-build-wont-boot/#findComment-10382143
There is a forum post on page one about this. Why does no one ever read it?
https://linustechtips.com/main/topic/42440-readme-how-to-respond-to-a-no-post-or-no-power-up-situation/
It's an almost comprehensive list of things to do in this situation. Good luck.
CompTIA A+ Certified
"We are all cups, quietly and constantly being filled. The trick is knowing how to tip yourself and let the good things pour out." - Ray Bradbury
https://linustechtips.com/topic/829791-fresh-build-wont-boot/#findComment-10389881
