Java CDATA XML Help
Solved by zombie-waffles,
I'm not incredibly experienced with JAXB, but I believe you may be looking for the @XmlAttribute annotation. I think one solution might be something like
@XmlRootElement(name = "Style") public class Style { @XmlElement(name = "IconStyle") private IconStyle iconStyle; @XmlAttribute(name = "id") private String id; ... }
I believe that should add an XML attribute to the Style tag (which if I'm interpreting your problem right is what you're looking for), and as long as JAXB's marshalling then properly marshalls the IconStyle tag, I think you'll be good. Also see https://stackoverflow.com/a/7498378
